Front axle job & locking the front diff
Ingerland
I read every detail in the FAQ write up on the front axle job. One hint was to lock the front diff as this makes it easier when refitting the drive shaft.
Having just done the job I can say that it was easy to replace the front drive shafts - easier than I remember it being the last time I did it without the diff locked.
Can I just point out the pitfall of this method - how do you measure the preload with the fishscales when you are not just turning one wheel but both front wheels... You can't.
My difflock doesn't disengage unless I drive the truck forwards or backwards. I can't do this with the wheels off - so now I have the difflock on and no way of accurately measuring the preload.. Is there an easy solution to this that I have missed?
Thanks, Jim
You had me confused for a moment, 'cuz it seemed like you were making some sense, then I remembered why it works. When you measure preload, the driveplate is not on, therefore the hub and the axle are not connected. You are only measuring preload of the wheel bearing in the hub.
At a certain point you cease needing to use the fish scale and you are able to do it by feel. I haven't used a fish scale in a long time. That said, after a birf job, I do go back in an tighten down the nuts a bit more just for peace of mind.
I also like my bearings a bit tighter than what the FSM calls for (IIRC, 12ft/lbs). I generally go to about 20 ft/lbs and call it a day.
These are industrial units...I would prefer a tighter preload as opposed to a looser one.
the FSM (1997) calls for 48 in/lbf which I understand to be 4ft/lb ... you may be putting about 3 (or more) times - torque .. although probably the actual preload reading is more relevant fwiw
(the preload is 6.4-12.6 lbf)
I haven't checked the FSM in ages. IIRC it was a range for which the preload could fall between. But you are probably right. I still like my bearings tight.
EDIT: Just checked the FSM (amazed I still was able to find it): 48in/lbs is indeed the spec.
:grinpimp:
When I recently did my birf job, and set my preload, the hub nut was at 40+ft-lbs, yup, way more than FSM, but preload was well within limits. I followed the advice of others that recommend setting based on preload, not torque of the nut. The first time I did the front axle job, I followed the FSM exactly, and I do not think the hub nut was tight enough at all.
I am not surprised that you needed more torque to reach the preload. My experience was that I had almost 10ft/lb (according to my "so/so" bar torque wrench) on the "adjusting nut" to hit 6lb/ft preload. BUT after I locked the adjusting nut and tightened the lock nut to the recommended 47 ft/lb .. my spring gauge increased to an indicated 10 lb - which is where I locked the tab on the lock nut.
Only did the DS last night and ran out of time .. so will see if the same occurs on passenger side.
(my hunch is that getting the preload within range is more relevant that the actual torque used on the adjusting nut .. assuming you have initially loaded the bearings to seat them and get the grease moving. On the other hand - if you can't at least reach the minimum spec'd torque on the adjusting nut without exceeding the preload - that might be a problem. Would like to hear form others if the think exceeding the spec's torque while remaining in limits for the preload is an issue or not)
Ben, you are right. I should have realised that.
I was struggling to get the preload anywhere near 6-12 lbs and thought I could blame the difflock. But thinking about it, this has no influence.
Maybe my preload is high because I have new grease which is still kind of thick compared to the slosh that is in there when I usually do the job.
I have set the torque on the nut to the specified settings and will just trust that for now. I'll redo the job once I have driven it for a couple of hundred miles..
That is a good idea. I had to retighten one side, as it was loose when it was getting aligned a few hundred miles after the new bearings/races. I need to check the other side soon, to make sure it is still good...
