Front axle install
Burlington NC
My front axle came in today from cruiserparts.net. Great company! It took less than a week to get to NC.
Awesome....looks like you need some bigger jack stands :flipoff2:
haha yeah, it just started raining so im waiting... There any tricks to this? Seems pretty simple.
So how many miles were on the axle when you got it? Did you think about a rebuild before install?
And I agree, CruiserParts.net is pretty sweet. Haven't ordered much from them yet, but it is nice to know they have such a nice selection.
Did you break or bend your old axle or did you just upgrade with factory lockers? I have been thinking about upgrading to factory e-lockers. It seems more affordable and easier to just buy a complete front and rear axle from cruiserparts.net than to add airlockers or even retrofit factory e-lockers.
I tore everything out of my old axle. So instead of rebuilding the old one i got one with 55,000 miles on it for 1400 bucks shipped...
Easy install?
Its pouring on the east coast today...
I got the new axle in, but the tie rod is too short somehow...
Anyone ever experienced this before?
Every other bolt went back in easily, but the tie rod wont line up.
ill post a pic soon.
That is not a tie rod; that is a panhard rod. Use a large HD ratchet strap (4" or so) to pull the body toward that side and the bolt will go in. One end of the strap to the frame, the other end to the axle, and then crank it to pull the body in the direction needed. I don't recall the torque number but it is pretty high... something like 90 ft/lbs. Look it up though because the torque on that bolt is important. Very important.
-B-
-B-
Sweet! Thanks B! I'll update after doing this tomorrow.
A BFH is your friend so don't hesitate to get it out if things aren't lining up. Don't bugger up that bracket though and don't bend the panhard rod.
-B-
Panhard Rod
The other option is to jack up the axle a bit, this should allow you to ease the panhard rod into place.
Good luck.
I had this problem on reinstallation of my front axle. I ended up unbolting the radius arms and sway bar again to give me some lateral wiggle room. I also raised the axle with a jack as mentioned. But IME it's easiest if you connect the panhard first, then everything else.
'Damnit! I gotta take everything apart, i tried the rachet strap thing, and it is jacked up right now. Guess i got a couple more hours of work, ill update when i can, thanks for all the help
-B-
BFH? Sorry im dumb... lol
haha ok, sweet... thanks
