Front Axle Boot Grease Leak
SAT
1999 with 330k. The front passenger axle boot has cracked with large amounts of grease coming out.
I don't know enough about these axle designs and setup but I'm assuming the Boot is suppose to be just a dust cover and not have grease in it? If that's true, then what should I start looking at and considering first?
I didn't want to tear into it until I understand more of what is at hand.
The boot is meant to hold grease. The grease leaking out is a bad sign
You can reboot it with toyotas reboot kit, assuming it doesn't click
Otherwise need to get OEM CV axle, I've heard nothing but bad about the aftermarket ones. Most Toyota dealerships are still running their parts sales
Clean it off and see if the boot is cracked or if the leak is past the band clamp at the end. If the boot's cracked, you'll need to a minimum reboot, could need a new CV depending on how long it's been/how much grease is gone/water intrusion. If it's the band, there's plenty of threads on rebanding and various clamps people have tried.
Thanks for the quick replies. Sorry, I forgot to note that were the red circle is, there is a sizeable crack in the boot.
I've been doing my homework as much as I can and ordered a new CV Axle assembly from the dealer. Price wasn't too surprising at $516+tax but more than I'd like.
Now to dig in on disassembly.
I read where someone noted replacing the CV Joint Seals at the same time. Searching has brought up mixed results on part numbers and images. Is this needed?
Do I need to drain the diff beforehand?
it's typically recommended because the seal is right there and takes about 60 seconds to replace with no special tools. I believe LH and RH sides have two different seals so that's where the confusion is in part numbers.
if you don't drain your diff, it's gonna be messy and you'll at least have to top it off a little
Gotcha. Dealership called back to confirm and used the opportunity to get the diff seal.
I just saw that the drivers side is getting bad as well, along with the upper ball joint. Will see how bad this run is first.
i did upper and lower ball joints, both cv axles, diff seals, end links, shocks all at the same time. All the parts come off anyways so might as well. My main thread has it documented, I think it was the first thing I had to do to my car
It doesn't appear you can replace just the upper ball joint, you have to buy the whole stupid arm.
Anyway of getting just the joint and can it be replaced? I've seen videos of individuals removing them but it almost seems everything is destroyed in the process.
tbf I replaced the entire upper control arms but I wanted something with more adjustment and travel
however I have read that you can press them out in the same way that you do the lower control arms, and buy the 555 ball joint kit from cruiserteq
oh, I forgot to mention. While you're in there check the condition of your hub flange. I didn't know to look for it and it turned out one of mine had a lot of corrosion so it wore on my brand new CV after just a thousand miles
Mines good.
I have the new axle in place in the hub and partially in the diff. Is there a trick to getting the rest of the axle into the diff? Have it snap into place?
Mines good.
The snap ring on the diff should have the open end at the very bottom iirc. I used grease to hold the snap ring in place
