Front axle advice
Round Rock
Hi, I bought a 91 fj80 a few weeks ago and it has what appears on the out side of the birfs to be leaking differential seals. I stuck some zip ties in through the square hole and while one side was a little low, the grease did not appear soupy. I did add more moly grease, it diminished the clicking but still there.
I do have some clicking from P/S when turning in a tight radius, can't be heard from the D/S. I tested this by having the wife turn figure 8s around me standing in a parking lot.
I have the wheel bearing play on the P/S (tested by jacking up one front wheels at a time and checking for play from 6/12 o'clock and 3/9 o'clock. Only movement was in the P/S 6/12 o'clock.
It also has some wobble when I apply the brakes at highway speeds. I assume this is from the bearing(s).
Took it to Dealer when I first bought it for check out. They said "replace both birfs due to not being able to be determine which one is bad," they mentioned the braking pulsing/ wobble was due to the caliper being locked at some point and wearing it unevenly. I ordered parts through them but they have not started work because it took 2 weeks to get them all in.
Should I just pick up the parts, other than the birfs and try to do the work myself? Or Take the parts to another shop locally ( not sure if they are cool with bringing in parts). I am worried that the P/S spindle is also worn and that would cost additional + them having to order. I know these trucks are expensive and don't want to start my ownership shelling out dealership service prices if I can help it.
CruiserDan gave me a MUCH better quote on birfs so i could order from him if needed.
There is a shop local that is going to give me a ballpark quote for similar work (waiting to hear if they also will let me bring the parts i bought from Toyota).
I also posted in the clubhouse section, but thought it might be more visible here.
Appreciate any feedback/ advice :)
If the birfs are grooved you could aftermarket seals (I think it's Man-a-fre that has a tighter seal that helps with if you have a groove, but double check this).
You can do this yourself. It isn't rocket science. It's actually fairly easy. Just messy. Like hella messy but fun!
I think you can handle it yourself if you review the FAQ and look at the jonesy YouTube videos linked toward the end of the birf thread.
It's nice to replace everything especially if you can't afford any down time and aren't sure what's bad. But if you can let it sit for a week or two take it apart and order only what you need.
I think i am going this route. Going to kit the axle rebuild kit and go from there, starting with the P/S. Where is the best place to get the 54mm socket? Thanks for the advice.
go here, about 1/4 the way down is the kit you need and they sell the socket too. mud vendors and really nice guys that can answer any questions for you.
They aren't OEM quality, but trailgear has axle sets that have the shorter clip position for the '91. Do it yourself, and buy something cool with the money you save.
https://www.trail-gear.com/TG/Longf...ed/i_0_0_3528/_301720-1-KIT.aspx#.Vb2x9fke024
Thanks for all the advice . I got a digital copy of the FSM. I ordered the axle kit plus rotors and a birf from CruiserDan.
Should I wait for parts to arrive before tearing into the axle? Not my daily driver. Thinking about tearing it down today in my garage to have plenty of time to clean it and check things out.
Next weekend (if parts are here) put it all back together.
Purchased what I did not have from the list on the FAQ and from Kernal for tools. I am super ready to get this thing done.
I have the passenger side apart now.
Hardest thing to break loose were the caliper bolts (see below). the lock nuts were both finger tight. initial pre-load weight was ~ 2.8 measured with a digital scale prior to looking at the lock nuts.
I think the problem may have been one of the trunnion bearings (if that is possible) . when I pulled off the spindle the birf drooped low. I lifted it up and down and it was making a very strange sound almost like a zipper going up and down. but the grease looked great in the birf (and knuckle) with no apparent mixing of gear oil and grease. The birf does not make any sounds at all out of the vehicle. it plenty of grease gushing around in there. The lower knuckle bolts were fairly loose. with one finger tight.
Some bad news. The two bolts that hold the caliper to the knuckle were badly stripped cross-threaded. the top bolt was a 19MM. lots of metal shaving came out.
Once its all cleaned up, i may have to helicoil it. i bought a tap and die kit on Kernal's advice. I will see if they can revive the threads or go bigger.
Trying to clean up the passenger side first, then starting on the drivers side. Need more de-greaser !!
x2 or 10 or whatever on doing it yourself, but if that's not possible, I have had good results by taking a competent mechanic genuine parts and if you like, a copy of the relevant pages of the FSM. I don't know if this is actually the case, but I felt like they actually appreciated the fact that I was trying to make it easy for them. (which I was, 11 hours away from home with a 12x6x7 trailer and having no facilities to fix the 80 myself)
I have the drivers side apart now too. Had to go get more de-greaser and containers for soaking. Drivers side parts looked good.
On the passenger side birf, what would cause the teeth at the end ( behind retaining clip) to Get chewed up? I am glad I purchased one birf.
It looks like there are groves and or gouges in the axle on the passenger side. So going to be placing an order for a new one monday.
Will add pics later, what are kids using these days to host images?
I would say that inner axle is going to be pretty tough to get a good seal on. I know some others have used different types of seals (especially Marlin) to get away from the grooves, but when I tried that, it only lasted about 5k before they were leaking again, and I didn't have the rough spots that your picture has. If the birds are good, you could just get new inner axles, since those are a lot cheaper, but if that first picture is where it attaches to the drive flange, those splines are looking pretty rough.
Separate note, one of my caliper bolts stripped out also, and I purchased a Timesert kit to replace the threads. I believe it still has a couple of the inserts along with the rest of the kit. I was really impressed with how well it worked. If you are interested, let me know, and I'll give you a good deal on it, as I'm not looking to replace any more in the near future. It definitely is cheaper to drill and just tap a larger hole, but I wanted to stay with the OEM bolt sizes, so I went that route.
Tales from the passenger side:
Assuming this means the birf is a goner.
One of the weaknesses of the early rigs, the splines are shorter, prone to wear/stripping. Check the drive flanges, they are usually as bad or worse. You can swap sides, maybe get more life or replace with the newer type birf/flanges sets.
Scoring, toast?
Hard to tell from the pic, but don't look horrible, have seen much worse seal, clean and smooth with emery cloth. One trick is to slightly overdrive the seal, only needs a slight amount to ride on new, smooth surface.
Thanks for the replies, I just bought an inner axle from CD. Already had a birfield on the way.
I am just having crap luck with the passenger side.
Here
Outer wheel bearing passenger front: I don't think that should be bent like that. too far gone? other than the bent outer cage it looked good.
could that have been caused by dropping it? I don't remember doing it...
Are these notches on the inner bearing (P/S front) a deal breaker or still good?
The drive flange looked pretty good. not mashed flat or anything like the birf end.
Thanks for the offer, i am going to see what i can do. I am trying to get a little bit done each night while waiting on parts. once i have an hour or two i will start cleaning threads and see what i can do with the tap and die kit. The bolts that did the striping did not appear in too bad of shape. the holes however... metal threads were coming out as loosening the bolt.
