Front axel woes!
Rosamond Ca.
This weekend I am on the 3rd front axel rebuild of the year. This time I changed gearing to 4.88, and added an Aussie locker. Given that, this rebuild is also accomodating my 3rd set of trunion berings. Each time this year I have rebuilt it I needed trunion berings due to shattering them. I am SOA, hy-steer, mini truck knuckles, pig inners, and longfields, and until this year was running 35" BFG's on an open front, and never had an issue. Changes earlier this year were only 37" Irok's. I assume my problem is rooted in the steering arm studs, but I am not 100% on that either, as due to the broken bering, it is my thinking that that alone may be loosening the studs a little. Am I doing something wrong, are my assumptions wrong? This is getting frustrating! Am I the only one who has had this problem? If not, point me in the right direction please. Thanks.
Hell no, don't loosen the studs. Are you setting the proper preload with the correct shims? When the arms are tight to spec you should have only a few pounds of resistance when trying to turn the knuckle side to side.
Having them way too tight seems like the only way that you'd go through 3 sets to me.
The shims in this kit (outlined in red)... Are you using them?
Actually I had just left what was on the mini knuckles when I did the swap. I never gave it that much thought. Thanx
The reason I gave it no thought, was I had the mini truck knuckles and hy-steer for a while before I ran into the bering issue.
What was your knuckle bearing pre-load?
Have you EVER checked this? It is covered very well in the FSM, and out here in MANY threads...
If you have not, and it was loose/not even close, you could easily damage bearings and races....along those same lines, if the knuckle studs have stretched and or they become loose and you continue to operate the vehicle, you could very easily pound the knuckle bearings apart...
Front Range knuckle stud kit might not be a bad idea too...
http://www.frontrangeoffroadfab.com/knuckle_studs.htm
Brian is a really good guy!
Good luck!
-Steve
Thanks much for all the input. For what it's worth, I have never checked the preload, and that must be my oversite. My studs may be stretched too, and now I intend to get the ARP's. I can't keep going redneck at this. Thanks again for the guidance.
DAMN!!!!! I feel like a jackass asking this question now. Took me like 2 minutes of searching to learn how to do this properly! Now all I gotta do is get the scale, and a new set of shims. The kit I just got came with cruiser arm pattern, doesn't fit the mini truck stuff very well. I'll be calling FROR Monday! maybe they can get me a shim set to go with new knuckle studs.
For my next dumbass question, "What do you guys think of revolver/scissor shackles?" :)
When you say "shattered", are you referring to the bearings coming apart or appearing to be in pieces when you take the housing off? My steering arm on the driver's side usually tries to pull apart the bearing when you tap it up and out. The bearing itself hasn't been damaged, but is during the dismantling process.
The bearings are coming apart before disassembly. I haven't messed any up during disassembly before. I am now sure it is due to not setting the preload, as has been previously mentioned here. I am just a dumbass is all, and is is costing me $$$, to include a bit of wear on a new set of tires.
OH YEAH I have done my research on the revolver/scissor shackles. It was my very 1st question on Pirate, when I got into the 4X4 thing. That should have tought me to search before asking or doing something stupid.
To 100% clarify. I need to disconnect the tierod and drag link off the arm, as well as the felts and wipers. Start with a base of a thick and thin shim, and put the scale (I'll call it a drag scale) on the steering arm and lightly pull until the knuckle moves. The tension/weight should be about 10lb, maybe a bit more with bigger tires?
Following up on AlaskanWheeler, the shims are made to fill your truck's specific shimming needs. They come in different sizes. Determining which size to use depends on your specific truck. If you are using the original knuckle and axle housing, then it's probably OK to set the pre-load by re-using your shims as they were initially installed by Tojo. However, if you are not using the original gear, or if you let the shims get out of order, then the FSM has a detailed description of how to dial-in the correct shims using a special service tool.
It can be a PITA to do the shims right, but so is tearing off your knuckles every 10,000 miles to replace your leaky axle shaft seals because the axle wasn't aligned properly to begin with. Not to mention that it's unlikely that you'll be able to properly set the preload without the right shims in the right place.
Don't forget to torque down the stud nuts each time you check for the tension.
