1993 FZJ80 100k original miles, garage kept
Hi Mudders,
I tried to chase down an electrical gremlin that was preventing my ECM from getting power and caused me to stall out while driving. All fuses and relays were good but my grey connector at the 3-wire fusible link wasn't reading 12volts. I replaced the wire from the battery to the connector and the ECM received power. ECM didn't throw any codes; however, when I took it for a quick spin the motor stalled out again and smoke came out of the hood and glove box. Popped the hood and pulled the power off the terminal. Smoke was coming from the fusible link wire I replaced, segments of the harness all the way up and through the firewall, and behind the glove box near the ECU.
I swapped out my 1993 ECM with the used 1993.5-1994 ECM (89661-60221) about 500 miles ago, could this be the problem (been running great since)? Given that the wire in the harness is probably completely fried, am I going to have to swap out the whole harness? Anything else I should check or could be the cause of this? Thanks in advance!
Hi Mudders,
. However, it was good because it gave me the opportunity to inspect all connections and test sensors with my newly purchased multi-meter armed a FSM.
...I couldn't be happier!
