Frame restore question
I know this probably has been covered and i searched, but ...
When blasting and painting a frame are there any tricks to getting inside the nooks and crannies inside the frame? you cant wheel it off and even blasting seems tough to get it all. and for painting im guessing that there are nozzles for spray guns you can use.
Anyone whos done a frame off , id appreciate some tips and tricks.
I think most guys just do the best they can. On my fj55 frame off, I just wire wheeled and painted, the frame was really clean though. I used a power washer and a lot of degreaser on teh frame first though.
Other's have done galvanizing dip, etc. And even others i have heard pull teh frames apart.
Noah
To get inside the box sections where a blast nozzle isn't effective enough, get a boiler brush. It's a bristle brush that looks like a bottle washer on a long wire handle. Get the loose stuff out, degrease it all, then get in there with a thick coat of Rustoleum Rusty Metal Primer. Use the can & brush. It's cheaper and the spray cans won't coat nearly as thick.
If you can still get it, and I'm not sure it's still legally available to consumers anymore, primer your frame with zinc chromate.
I Just Got Finished Wheeling And Blasting My Frame And There Is No Easy Way. I Only Blasted The Nocks And Cranys And Inside The Frame Rails Best I Could And Then Took My Wifes Toilet Brush And Coated The Hell Out Of It With Por-15. Then I Went Out And Bought 2 More And Used Them ( Get Rid Of The Evidence ). One Trick That I Did Learn For My 3 Year Old Is If You Take The Foam Ear Plugs( Why She Tried This I Will Never Know, She Said She Wanted A Place To Hide Them From Me) And Stick Them In The Bolt Holes You Will Not Have To Re-tap Them Later And You Can Push Them Out Easy And Re-use Them. So Other Then That, I Got Nothing, Just Time And Hard Work
i recently got my frame blasted at a place down in hayward, ca. and they did a good job. got inside everywhere. Then i had it powdercoated also a place in hayward and they got into all the nooks into everywhere.
Its possible. You just have to take your time i guess.
I wonder, is powder coat more durable than por 15? gotta be more expensive. i guess i'll be getting some plugs and toilet brushes. the frame is the one thing i'm not excited about working on, still debating sourcing it out.
I had my frame sandblasted and it came out perfectly clean, didn't see one missed spot. The blasting cost me $180 and they would have powder coated it for I think if I remember right another 200 more. I ended up going the POR route and that cost me about 150 (to do it right) that includes all the cleaning products, metal etch, gray under coat and black top coat. Went back and reviewed my time log and the whole thing took me about 16 hrs. I may be more anal than most but it did take me a weekend to do and as far as inside, lots of time with a brush and the rest I used a HPLV gun to basically fog inside rails. Total I did 5 coats. 2 gray, 3 top coats.
With the time involved the powder coat may have been the way to go, but I did use the POR on many other parts on the chassis that I wanted black and durable as hell, skid plates, front and rear ends, stearing boxes, tie rods, ect. For all those others it was nice to just open a can and do and not have to go back to the coater to match my frame.
I have progress pics on my site if interested.
Nothing Nicer Then A Clean, Painted Frame Ready For Parts. After Your Done It Feels Good
The frame is one of the easiest parts of resto. ;)
Just wait, it gets better.....
Had mine sandblasted inside and out. Two coats of Rust Bullet were applied. Then chassis black. Here you have to be creative. I used bristle brushes and tooth brushes to get inside, and to get way inside and the back inside of the frame I took a bbq. brush you know the cheap long wooden handle ones, Bend the brush at the metal that holds the bristles somewhere between 60 and 80 degrees. You can useing this and the tooth brushes get every sq. inch. Wear gloves this stuff will not come off anything it touches. I did not learn till too late that you cannot use frame paint directly over rust bullet. To adhere properly you should first spray with epoxy primer. Cannot comment on longevity as I an still building and have not had my cruiser out in the weather since painting. If it is going to fail then the whole thing will fail as I am coating everywhere that could rust with this product.
