I decided to start a new thread on this and take it outside of my build thread because it is such a specific question. Sorry for the length, but searching reveals no direct answers.
I am at the point where I am ready to refinish the frame. I have rust in the rear C-Channels and by the rear spring pins. Some of the body mounts need reworking. The rear cross member needs to replaced or new metal welded in. If you haven't already seen them, look at pictures here: https://forum.ih8mud.com/showthread.php?t=128847&page=6
My original plans for the frame are as follows:
- Remove C-Channel from rear of frame, weld in 3/16" sheet to box in the frame. Reattach body mounts and rear shackle hangers.
- Cut out metal by rear spring pins and replace with new metal (I think 3/16" was factory?). Add a long patch plate over the new metal to add some strength to the area.
- Sandblast frame.
- Paint frame with Rust Bullet (or similar) and topcoat for looks.
- I can't sandblast inside the frame rails as there are very few holes in it.
- I can't paint inside the frame rails as there are very few holes in it.
- I have seen people do sandblasting and paint in the 45 section and they have large round holes on the inside of the frame rails to work with.
- With no protection on the inside of the frame, will rust just start over as the water/mud enters the frame and has no way to exit? Since I can't sandblast the inside, the rust will still be there.
- I am not asking what paint/coating works the best, but the only way I can see getting to the inside is hot acid dip/galvanizing. I have seen prices from $250-$500 to do this. Anybody know a place in the Denver area?
- What is the real danger of doing nothing to the inside of the frame? I am not looking for a 100 year life span, but I would like to get 15-20 more years.
- Can I cut access holes on the inner frame and add additional patch panels around the holes? This would give me access to the inside, but the extra material would help the weakened frame. (A LOT of work!).
- Do they make long sand blasting attachments? I could do this and soak the inside with paint (lay it on REAL thick and let it run).
