Frame plugs??
Western Nebraska
1992 LC, but probably very similar to 93-97.
I'm planning a major rust proofing treatment to my truck and have noticed that the frame has a significant amount of rectangular and some round openings--both on the outside and inside of the rails. Some of them, notably the ones on the outside of the frame rails in the rear wheel well have plastic plugs, OEM PN 90950-01395 (rectangular) and 90950-01675 (round). My question is whether or not all of these openings should have plugs? They seem like a prime place for dirt/mud/etc. to enter the frame and get stuck in there causing further potential for rust and corrosion...
Is there any reason to not plug them?
Attachments for reference...
For the frame parts drawing, I have circled the referenced plugs and also a rough location for the plugs (although I'm not looking at the truck--just at some random photos I have)...
My only concern would be that any moisture that gets trapped in the frame then won't have the ability to easily evaporate.
The only sure fire way to eliminate all moisture entry would be to seal with some sort of FIPG or welding them up....then I would be concerned with the frame sweating and moisture building on the inside...trapped...
Some of mine have covers, some dont
No. The majority of holes did not come with plugs from the factory.
I spray water in those holes to wash away accumulated debris. I follow up with Fluid Film at least once a year.
Some of mine are plugged and others aren't. I wouldn't worry about it. Weep holes are placed on the bottom of the frame for drainage. I did think about plugging a few because the frame fills with mud. I spray inside the rear wheel well every time I wheel.
Thanks for the help! I think I may leave all the ones under the vehicle open, but plug the ones in the wheel wells. Those look like they'd definitely get some direct spray of water/mud/crap that could cause issues.
