Frame Off Restoration FJ40 $90,000 invested 756 Miles
Mint Condition Frame Off Restoration FJ40
$90,000 Invested
I can't believe I'm actually doing this but unfortunetely the time has come for me to move my baby. Getting married in 6 months and the dreaded practical argument has entered my head. Wanted to have an opportunity to sell her to a Cruiserhead so I thought I would post her here first before I explore other sales options.
Beautifully restored, professionally built, rust free body, California 1972 FJ40 Toyota Land Cruiser with 756 miles.
The garaged Cruiser was built by the Land Cruiser specialists at BTB Products. BTB Product's custom built FJ40s have sold for well over $100,000. Here is your opportunity to own a vehicle built by mechanical engineers & Land Cruiser enthusiasts. This smog exempt "Show" quality vehicle is ready for the trail or the highway. Almost every part, nut, bolt, bearing & gasket has been replaced by a new one and the old ones have been painstakingly cleaned, sandblasted and painted. I am confident this is the nicest Toyota Land Cruiser FJ40 available - You can EAT off the exhaust manifolds and frame.
ROLLING CHASSIS:
  • Frame—The Cruiser has been built from the ground up. The frame was stripped all the way down, sandblasted, polished to perfection, and powder coated black.
  • Motor— The frame was set up with a 345 HP ZZ4 350 Small Block Chevrolet motor with aluminum heads & Centerforce clutch. An new Edelbrock 750 carburetor fuels the Cruiser. Edelbrock air filter The cruiser has had the stock gas tank gutted, cleaned & repainted with all new fuel lines and hoses. A confer rear gas tank has also been installed so that more fuel can be stored with an electric crossover switch. Both fuel doors (Front & rear) come equipped with built in locks. All new hoses and gaskets.
  • Transmission—Attached is a rebuilt SM420 transmission, with a 4SP Ranger Overdrive unit and Toyota Land Cruiser transfer case. Advance Adaptors bell housing. All new leather Momo shifters for Transmission, 4WD & Ranger Overdrive Unit.
  • Custom made front motor mounts, scab plates, front steering correction kit, power steering plate and the rear truss were welded into place.
  • Springs—Custom made spring mounts and reinforced gussets were added for strength. New Rancho Springs and new power steering box were bolted in. 1 1/2" high 2" round black powder coated aluminum body mount block were used to lift the cruiser. 12 blocks total. In the rear of the truck a custom 1 1/2" x 2" rail was installed to eliminate the gap between the body and frame. The rail and blocks were made of 6061 aluminum and powder coated high gloss black. They were mated with a body mount kit using polyurethane pads.
  • Drive shafts—Special drive shafts were constructed for both the front and rear.
  • Axles—The front and rear axles were completely rebuilt
  • Brakes— Front disc brakes and new rear brakes with new brake lines were installed. A later model brake and master cylinder combination. New emergency brake hardware
  • Tires & Wheels— 35x12.50 BF Goodrich Mud Terrains were attached to 15x10 Centerline HTs. A full size spare 35x12.50 BF Goodrich Mud Terrain & 15x10 Centerline HT come attached to a reinforced custom built rear tire carrier.
  • Rancho shocks, bumpstops, greasable shackles, and pins have also been installed. Most every part has been replaced with new parts or the old ones were sandblasted and powder coated. Stainless hardware used throughout.
  • Exhaust—Sanderson QP 1000 exhaust manifold headers were installed mated to a three-chamber Flow-master to handle the performance end of the exhaust. The custom built exhaust was designed to keep it inside the frame rails to protect the components when on the trail.
  • Radiator— A five core radiator & fan shroud were installed. All new hoses & a powder coated black factory grill.
  • Body—FACTORY FOLD DOWN TAILGATE with new latches and chains. The tub was sandblasted and reinforced. The body was prepared and prepped for painting. Indian Red Custom paint job was provided by award winning body shop Michael J's of The Alamaden & Curtis Custom Classics of San Jose. Attention to detail was paramount so all pieces ( Tub, Hood, front Bib, New Fenders, front Aprons, late model FJ40 Windshield frame, Windshield motor cover) were all individually painted. To protect against the elements and rust, the body, including transmission Hump pan, was then thoroughly professionally Rhino-Lined inside and underneath. Stainless steel hardware was used to bolt the body into place. BTB powder coated Side Protection, mud flaps and Bushwacker Fender Flares were then installed.
  • The hood was setup with new rubber pads, hood hinges, and windshield frame stops using stainless steel hardware.
  • New Windshield glass and rubber gasket were used. The Windshield frame was mounted to the tub with a new rubber gasket between them. A new windshield motor, gasket, and linkage were installed underneath the wiper motor cover.
  • Recaro Seats—A new $3,000 set of heated powered Recaro orthoped seats with custom made powder coated seat brackets were installed to provide plenty of support for the trail or streets. Seat cushion extension, climate control, fully padded head rest with height and tilt adjustment. Electric recline adjustment and electric recaro airmatic lumbar support.
  • Jump Seats —The jump seat frames have been sandblasted and powder coated. New jump seat cushions and newly upholstered jump seat covers have been installed using stainless steel hardware.
  • Seat Belts—New 3-point retractable seat belts are bolted to the cage assembly. Special plates were welded to cage prior to powder coating. New retractable lap belts were installed for the Jump seats.
  • Tuffy Center Console—An 8 inch Tuffy Center Console is setup on the custom seat frame assembly. It provides plenty of lockable storage, padded cushion armrest and a dual cup holder is installed up front.
  • Roll cage—A $3,500 BTB custom made powder coated roll cage. The front section of the cage was opened to increase extra head room and special gussets were added throughout the assembly. NOTE* The seat belt mounts on the center bars and the head room clearance for the rear jump seats. The roll cage assembly is installed with 8 grade hardware. Custom built 2x 1/2" speaker housing was built into the front left and right bars of the cage prior to powder coating. To ensure that the tub and cage stay together in the event of a roll-over, special bottom plates were fabricated and installed for added security. Two fire extinguishers attach to fire extinguisher brackets bolted to rollcage.
  • Steering—Rebuilt saginaw gearbox, new power steering pump, relay rod, power steering hoses, tie rod ends, pitman arms and power steering box mount. New steering yokes connect with a specially designed BTB telescoping steering shaft. A new steering column anchor centers the column shaft through the firewall.
  • Tilt Steering Column— The 5 position BTB tilt adjustment steering column was painted to match the interior and exterior paint job. The column is mated to a leather Momo Club 4 steering wheel. A steering column mount sets the correct angle and bolts directly to the firewall.
  • New gas pedal assembly is bolted to the firewall using BTB pedal mount bracket.
  • Electrical— New 12 circuit V8 conversion wiring harness, Mallory coil, Hyfire VIA microprocessor ignition system, Mallory master coil, Hamburger starter, and Optima battery. New turn signals, headlight assembly, Hela head lights, and brake light Assembly.
  • Stereo, Amps, Speakers—Two 2 1/2 " tweeters built into custom made roll cage. Kicker 02VS10L7 Solo Baric sub Woofer installed into custom made box housing rhino lined and bolted to tub behind driver and passenger seats. kicker KX600 300 Watt x mono subwoofer amplifier in custom powder coated assembly between floor and seat assembly. Two Pioneer TS-A6995 6"x9" housed in tuffy outdoor locked speaker cabinets.
  • Gauges—BTB engineers fabricated a new dash plate assembly that houses the components. The center gauge cluster houses the speedometer tachometer and clock. The 4 gauge cluster to the right houses fuel, oil, water temp, and volts. To the right of that is an aviation compass and altimeter.
  • Dash— All new factory Dash
  • Hidden Security kill switch installed to prevent theft.
  • All new Turn signal arms, wiper arms, wipers,& switches,
  • Doors— Custom made half doors were cut using 1972 FJ40 doors. New stainless steel door pins & new door strikers were used along with new door handles & new locking mechanisms.
  • Bumpers—BTB Rear channel bumper powder coated and welded into place with a built in tow attachment. BTB front bumper Powder coated and bolted into factory holes. Powder coated BTB high lift jack towers are used to mount high lift jack with optional axe and shovel mount.
  • Mirrors— All new mirrors, arms, brackets and hardware. New rear view mirror.
  • Warn Winch XD9000I— The 2.5 HP motor has 9,000lb capacity for high performance heavy duty applications. It is mated to a BTB products powder coated winch mounting plate with tow hooks.
  • Soft top— Black Fast Trac w/two pce soft doors and hardware installed.
  • New rear license plate bracket, license plate light cover, and light assembly.
  • Emblems— All new emblems and gaskets direct from Toyota were used.
I am the 2nd owner of the cruiser. The 1st owner used the cruiser on his vineyard in Paso Robles California. I have invested many years and a lot of love in this Cruiser. It is very painful to part with my FJ40, but like I said I'm getting married this summer and it has come time to pass her on to someone who will love and appreciate her as much as I have. She is simply the most beautiful Toyota Land Cruiser I have ever seen. It would be difficult to find a cleaner Cruiser for sale. My loss is your fortuitous gain. I have 180 photos of the Cruiser & the restoration process at the link below. http://s86.photobucket.com/albums/k106/jtelford/
The Cruiser is located in San Francisco CA. Willing to assist in Shipping or pickup.
I'm asking $20,000 OBO
*SERIOUS BUYERS* If you have any questions please feel free to contact me by PM or email.
Thanks for looking!
<a href="http://photobucket.com" target="_blank"><img src="http://i86.photobucket.com/albums/k106/jtelford/2-1.jpg" border="0" alt="Photo Sharing and Video Hosting at Photobucket"></a>
HOLY CRAP $100,000 INVESTED :doh:
I HAVE 1 WORD OF ADVICE FOR YOU... EBAY:idea:
THIS TRUCK WILL BRING WAY OVER $20K:cheers:
GOOD LUCK ITS BEAUTIFUL!!!
[/quote]Thanks, Ya'll! She's been bought sight-unseen. Just pics. Had to move fast... she was underpriced.
She's moving to Dallas.[/quote]
Hey Texican if you are the new owner:cheers: you stole that one great job:grinpimp: Like you said had to move fast good deals wait for anyone
Underpriced is an understatement in the case:doh:
Congrats and I hope its everything and more than you expect!
*SOLD* Thanks to all that responded
She's going to go a good home in Dallas. Not sure how Havis's brother's buddies are going to feel about the Niner paint job in Dallas but I imagine there still may be some drooling involved.
I'm feeling the pain of a great loss right now.:frown:
Thanks again guys!
Jim
Hey Jtelford,
Why didn't you reply to my email or pm on Friday?
Dcannon dont worry bro just forget about it another will come your way... It just wasnt meant to be, keep cool and you will find the one or better yet it will find you. What are you looking for specifically? Post a wanted ad in the vehicles for sale section:idea:
Good Luck with your search and enjoy the forum:grinpimp:
Thanks Addict, I just didn't understand why my correspondence was never returned since Friday, but someone else emails and gets a response.
I am a soon to be reformed early Bronco owner and on the classicbroncos.com website, whoever posts first while sending an email and/or PM gets the first right of refusal... that does not appear to happen on this board. :confused:
David - Don't take it personally that I did not respond to your PM or email. First of all I didn't see any emails until this morning. Believe it or not there were several interested parties. In your email you said "I'll take it." You did not however make a best offer. Did you think I was kidding about OBO? Well a few others did not overlook my stated OBO & bid Significantly higher than what I posted it for. Am I not going to do what's in my best interest? They wanted to make sure they closed me without them having to worry about getting into a bidding war with somebody for fear of losing out. That is how you close a deal. I don't know where you're from but in my world if you see something good come along you better be prepared to strike while the irons hot. Unfortunetely that usually involves opening up your check book. You never threw out a figure - They did. Coffee's for closers.
I have a huge checkbook... how much did you get? I would have paid more...
Where I come from you would communicate to the interested parties and take the highest offer...
I was attempting to "strike while the iron was hot". When I wrote "I'll take it", I meant let me know what I need to do to own it. My fault if I did not spell it all out. I thought that by leaving 2 phone numbers and 2 email addresses, we could speak face to face before you accepted an offer elsewhere.
I need the Glen Gary leads.
Not concerned that you would have given me more. He made a fair offer that looked very attractive to me. I took it - Nuff said.
Like I said, I really do appreciate your interest & I'm sorry to disapoint you but I did what I thought was best for me & my current situation. Good luck with your search.
I bought it...
I guess I lucked into this one. Its an awesome looking Cruiser. Not sure about the 49'er colors, but what are you gonna do? Does anyone know of a good hauler I could use to get it back to Dallas???
F'n F'r, go and get it. Won't that POS Discovery you drive now pull that new ride? San Fran is nice this time of year. Really, look at MUDship and see if there's anything going from there to here.
When the heck did you register here? All the Cruiser info you ever need is here. Check out the 'search' function and peruse the different forums. Woody has developed a really good Cruiser site. Really.
Sign on the line which is dotted.... First prize a FJ40-- second prize, a set of steak knives! At least you are not looking at 3rd! Maybe you should make him an offer he CAN'T refuse....
dhavis;2023424 Does anyone know of a good hauler I could use to get it back to Dallas???[/quote said:
I know a good hauler, maybe not the least expensive, but he gave me a fair deal and had good comms, look him up on uship fearlessfossil pm me and ill give you his e-mail address if you want it.
BTW congrats :grinpimp:
What did you pay for it?
