"Found" Power Steering system part
Malleus
contact@RESTORE4x4.com
Supporting Vendor
Charlotte, NC
The NLA return tube for the (62 series, 1987–1990) power steering gearbox, 44416-60061, is also a Toyota forklift part. Same number.
TruPar.com has it listed (currentlly backordered):
I haven't looked for it anywhere else, but I'm lazy because there's a Toyota forklift center in Charlotte.
I looked at this some years ago (the 60061 tube also fits back to 1981 40/60). There are quite a few 'tubes' for that power steering return that have the same size threaded nut, but with slightly different tube shape.
I think anything from a Hilux or T-100 or 70-series and many others, works just fine, but I don't remember any part numbers. ToyotaMatt used to have all this listed on his website, Vintageteqparts.com but I don't see it anymore.
I don’t think you will actually get this part.
Also, all Toyota forklift parts end in -71
Another indicator that you will most likely not receive this part.
Pleeeenty of other still-available Toyota options that work as a direct replacement for this. I’ve found at least a half a dozen
70/80/105/200
care to share?
44416-60190 is the one we normally stock and use. Virtually identical to the original part.
Any idea what the difference is between -60190 (100) and -60311 (80)?
-60190 doesn't show up in the EPC, but -60311 does.
they are all virtually the same and interchangable across basically all Toyotas.
