I'd definitely go 4.8/5.3/6.0 iron truck motor and I've got a 4.6 mod motor in my Mustang. 5.3 would probably be better since they're so much cheaper than the 6.0. I've seen a complete one pulled from a running wreck for $500 with intake and accessories. Probably not a typical price, though. 285 hp or so stock, but easily upgradeable since its basically a small, heavier LS1. 6.0's seem to cost alot more since the F body guys snatch them up.
As far as I'm concerned, the newer GM V8's do everything better than the Fords, and in a smaller package (outside dimensions). Good for swaps since its been done so many times, in so many different vehicles, and there are so many people selling wiring harnesses and programming.
Too bad GM can't put anything decent around their drivetrain...
FWIW, I think this project could cost 20k+ more than planned. I looked into the Volvo axles before I got my air lockers. Ouch. If you're going to swap axles anyway, you could open up your transfer case options.
Can't even imagine putting a carb'd motor in the 80. Carb's just don't run good on the trail, not to mention you might have to pass emissions sometime in the future, depending on elections, etc.
Resale value would go down with a carb'd V8, up with a diesel or efi V8.
If you stay with the Ford, I've got an Early Bronco transfer case in my garage that I need to get rid of...
