- Joined
- Apr 19, 2006
- Threads
- 33
- Messages
- 155
What's missing here?
lol... My plan was to swap in an 80 or 60 series rear axle, and toss in my center section. I'm popping open the case tomorrow AM and see if the ARB is damaged. Then try to identify the gear ratio (in there when I bought the truck). Then pray that 80 series rear came with this ratio. Then try and see if my ARB will work... Anything wrong with using factory FJ80 rear locker?
I want more width out of the rear, doing a slight stretch out the rear, and tossing my rear wheel spacers (1.5" each) upfront to make up the difference. As for suspension, will be an independent 3 link with coil overs front and rear. I just have to figure out what to do with my rear AUX tank, but for now I can pull it and run off the factory for now.
I have a '67 FJ40 with 35's. For the drivetrain I have a built SBC with SM465 tranny adapted to a ealy 70's 3 spd toyota case I believe. Which brings up another question, is there any way to remove that big parking brake drum in the rear of the t-case? It kills ground clearance and my cable's broke anyways.
So yeah basically I've been tossed into this project much sooner than I wanted, which means I haven't done as much research as I'd like. Please feel free to critique, complain, help, suggest, or whatever. Thanks.
I'm fighting to rip out the pinion. Prying open the thirdmembers crack. Can anyone think of an easy easy way to get to the c-clips with an ARB. (I've never had an ARB before).
