For Sale / Wanted To Buy
ISO the rear upper quarter panels - preferably both sides but if not the passenger side at least - for my 1978 FJ40 LC. I’m describing the steel panels that hold the 2 windows nd curved glass and that attach to the hard top. Any leads on where to locate them or have them fabricated in the Upstate, if you don’t have them for sale, would help. Just got the LC a few weeks ago and setting out on a restore after the frame-off one done by the prior owner 20 years ago.
I’m a new member of TLCA and trying to soak up ih8mud knowledge and resources. Thanks.
Sale is pending….
I’ve recently listed some 62 parts for sale on the MUD classifieds…I also have this 22.5” light bar that was on my 62 when purchased. It’s quite hefty so I’d prefer to sell local than ship…$40
I’ve got a gas tank for an fj60 in very good condition, just removed it from my truck. Asking $100. The sending unit is not included as I have modified it for my larger tank.
Which larger tank did you get? I was in a rush using a borrowed lift when I put my high capacity tank in so didn’t modify the sending unit - I’m interested in how you modified it.
I got a used one from trollhole that may have been home made, to modify the sender I carefully removed the wire float arm and replaced it with a longer one I fashioned from an insulation support rod. The rod is about the same diameter. So far it seems to be working, though I haven’t filled it all the way up to check that reading, it reads almost 1/4 tank with 19 gallons
Check your messages.
Regards,
I have 78 sides. Check your messages.
Gang, I am selling my FJ43. Full history of what I have done over 4 years here:
Short info: 1981, Vintage Air, power steering, rebuilt top end (machine shop), hard top, 5 speed and split case. Asking $35,000
Stand Alone Vortec 5.3 computer, diagnostic module, and harness for sale
This harness and standalone computer came with a Turnkey aluminum 5.3 back in 2011. The engine developed a crack between cylinders 5 and 7 a year ago and was swapped out with an Iron block replacement. I was told that the harness was built by Howell Engine Development, and the standalone computer is not programmable. Included in the sale is a Techmate Pro diagnostic reader ($500 value).
(TechMate Pro marine diagnostic tool, marine code reader)
Asking $150 or best offer for all parts.
SeriesLR(at)gmail(dot)c0m
SOLD
Next up on the garage clean out/up....
I'm beginning to work through tying up loose ends on the 45 for an eventual transfer to new ownership (yeah, I'm getting old-er).
I figure the desirability factor would probably go up a few points with a tall skinny tire on a stock rim with hubcap, sooo.......
I have five 35x12.50R17LT (Load Range D) BFG KM2 on Trail Ready Beadlock with 6-5.5 pattern for sale. Tires all measure around 16/32nds and have a date code of 4312. No rips, splits, or plugs. All wear is straight and true. Beadlocks are TR part number HD17 measuring 17x8.5 with 3.5 inch back spacing. Bolt pattern is 6-5.5. Beadlock rings have a few small scratches/rock rash, but not bad at all. (Trailready TR Beadlock HD17)
Asking $2000 or best offer for all 5. Located in the Charlotte area.
SeriesLR(at)gmail(d0T)com
Looking for a cheap vehicle to buy or rent. Helene destroyed our private road and it could literally take months to rebuild. Need something on the other side. We’re ok and the house survived so thankful for that. Thanks.
Good to hear y’all are ok
