FOR kit purchsed
Oceanside (San Diego)
Website
community.webshots.com
Well...I finally decided on a lift and called up Frankie yesterday to order my lift. It should be shipped out Jan 3rd or 4th and will be anxiously awaiting its arrival.
Hopefully I should have good news to report on the on/off road handling with 315's.
First impression was he seemed very knowledgeable on the 80's and is sincere in his desire to have satisfied customers.
I'm thinking hard about getting an FOR lift within in the next month or so for my 80. Got a few things going on first.
Anyway, keep us informed with how the install goes and some how the post install trail testing goes.
-Ferg-
I'll be sure to keep you guys posted. Can't wait to get it out on the trail.
Also noticed that I can't spell...("purchsed") :D
Congrats on the purchase. What size springs did you get? 3" lift, 3.5" lift, or something bigger?
What are you going to use for castor correction (the bushings or something like landtank's plates)? I'm interested in the FOR kit too...
Got the 3" in the front and close to 3.5" in the rear since I will be running a rear bumper and swing out.
I plan on starting with the castor correction bushings and go from there.
I plan on starting with the caster correction bushings and go from there.
that's probably a mistake. You will most likely fall short and then not be bothered to correct it. Do it once and do it right.
But if you do go with Frankies bushings send 2 to me and I'll draw up a press template for them specifically. Someone tried the Slee template and it wasn't quite right.
What kind of problem do you see with using Frankies bushings? Others seem to be happy with them.
What do you see as a better solution?
I just don't think the bushings will correct caster properly. People liking it doesn't play into the equation as far as I'm concerned, it's either right or it's not.
How much weight have you added as far as bumpers, sliders, winch and so forth?
What is a better solution for castor in your opinion?
The only weight I have added so far are the I8HMUD and TTORA stickers.
I plan on adding:
Front Bumper (no winch)
Rear Bumper with tire swingout and hi-lift
Sliders
Basic tools
Sometimes carry camping gear
I plan on adding:
Sliders
Basic tools
I think you are going to need caster plates. Nay and others have repeatedly pointed out that the FOR springs don't loose much in height when you add weight.
On my truck I have Slee's 4" springs but with all the added weight it's more like 3" of actual lift. I have plates on my truck and am at 2.8* for caster.
If the FOR springs actually yield 3" then with his bushings you're likely to get less that 1* of caster when all is said and done. It might not seem like much but a couple of degrees in caster makes quite a big difference in the handling.
OK...as stated before, I am new to the 80 and this is how I understand it...3" of lift will yeild a negative castor and the 2-3* bushings would yeild about a +1* in castor. Is that about right? I am guessing that the castor plates, such as the ones Slee has, are good for about 4-5* in castor?
I'm not sure how much Slee's plates yield but I think that it's in that range. If after the springs are installed if the measurement from the center of the wheel hub to the bottom of the fender (measured vertically) is @ 23" you will likely need caster plates to completely correct for caster. With using any caster plate, needing a DC Shaft is also likely. And at that height adjustable panhard rods are often used to correct axle offset.
....and so it begin$$$$$ Good times!
Yes but the consolation is that when done correctly the truck will drive amazingly well both on road and off.
I agree with Landtank. I did the Slee blue bushings for a 2.5 inch lift. But with bumper and winch it was more like 1.75 inch lift. My caster was 2.0. Anything past a 2 inch lift I would do plates.
How about the 4+ control arm drop brackets from MAF? Wouldn't they correct for about 3" lift? Is there some disadvantage to them that I'm not aware of?
They seem to work for quite a few people but there was one person who had some driveline vibrations that he couldn't resolve. Going with any MAF product you need to know up front that your pretty much on your own. I bought one of their 4+ brackets. It came with no install instructions and had to be modified to work correctly. I'm very pleased with the end result but I'm not sure everyone would have had the same out come as me.
