After (way too) much deliberation over the last 3 years of ownership, I finally installed a lift. I went with Frankies 3" kit (actually springs, shocks and shock adapters only) and some other parts sourced from Mud members and other vendors.
It's a long story as to why I didn't just source it all from Frankie (which in hindsight I would recommend), but the short of it is that a few months back I bought Nay's rear FOR gen 1 springs, and was originally going to go with those and OME heavy fronts. I finally concluded that this could lead to possibly unlimited trial and error scenarios, and not only did I not want to waste the money, but the time to engineer a hybrid lift.
My biggest problem was that I was dead set on only wanting 3" of lift, no more, no less. The reason for this is that although it's not my DD, I use it primarily for hunting, and it's a PITA having to lift dogs in and out of the back of a truck, let alone accessing gear repeatedly throughout the day from a tall truck. I also did not want to get into Caster/DC shaft hell.
And anything less than 3", well, what's the point?
I dicked around too long because of this 3" objective, because until I called Frankie, I was under the assumption that all he offered was a 3.5"+ kit. It was then that I found out he could set me up with 3" front springs. I was still going to use Nay's springs with the fronts from Frankie, but he accidentally sent me a whole set, front and rear. Not feeling like jerking around with trial and error at all at this point, I installed the springs Frankie sent, and I'm planning on selling the springs I got from Nay.
At the same time I installed the lift, I also added:
The only issue I ran into was the front bump-stop rubbing against the spring (I know Sam had this issue also). What I did was remove the steel cup from around the rubber portion of the stop and bolt it back up. No more rubbing (well, metal-on-metal rubbing anyway). I may convert to FJ62 stops, as Rick mentioned in Sam's thread.
I also flattened the tops of all the springs with my 4" angle grinder. Probably not necessary, but I was feeling fabby.
As far as the 3", no more, no less...Unfortunately, although there's 3" of lift in the rear, It sits exactly 3 1/8" higher in the front. Unbelievable. I guess I forgot to tell him I only had 1/2 tank of gas.
Here are the pics.
1st one, is obviously pre lift/arb.
- an ARB non-winch from bumper
- Slee TREs and MAF relay rod (already had Slee Tie rod)
- OME steering Stabilizer
- MAF rear panhard drop bracket (from Nay)
- Slee front sway bar drops (used from mud member)
- Blue CC bushings, with Landtank's template
- New OEM front control arm, frame-side bushings
Here are the pics.
