Foggy windows
My 96 Cruiser fogs up very easy.You need to run the a\c when we get cold weather and then its not to effective.I dont smell the telltale coolant fron the heater core but I suspect its the propblem.Am I on the right track or is there something Im missing? Thanks for the help!!!!This is a great site,I have been browsing around for a few weeks .
Switch your heater to external air from internal, this will help. You can crack your front windows for a few minutes as well
For maxiumum window clearing power...
Push the button on the far right for the defroster vents.
Push the button for bringing air into the vehicle (not the recirculator).
Put the blue/red slider all the way to the red.
Turn the fan up all the way.
Turn the AC on.
The AC coil sucks moisture out of the air then the heater warms it back up. Warm dry air = clear windows.
If you're in a region with snow, the air intake vents under the windshield wipers can be covered with snow. Be sure to brush those off. Anything that falls into them is going to get sucked into the system and come out as water vapor onto your windshield. When I know its going to snow, I pull the 2nd row floor mat and put it carpet side down over the vents. If the wind is blowing hard, put it under the wipers too.
