Fogging windows in the cruiser
North America
I have been battling foggy windows in my 96 cruiser for months now. It seems to do it whether the heat is on or not but happens a lot faster with the heat is on. Using the AC or having the windows cracked obviously fixes the problem temperarily but i would love to get to the bottom of the problem. Ive checked for leaks and found nothing however the truck appears to be losing coolant. anyone have suggestions?
Usually happens when you are circulating air internally. 3 different methods you can try.
Set your heater to use outside air. Should keep it from fogging (depending on humidity)
Also, the fog will quickly go a way with the AC on. The temp does not have to be on cold for the AC to be on.
Finally, cracking a window helps.
BTW- You should get your coolent loss checked, but this has nothing to do with it. Normal operation on internal circulating air.
perhaps unlikely but if coolant is leaking inside the cabin (heater core(s) fpor example) it could be a factor with fogging - high interior humidity. Find the reason for the coolant loss. Good luck!
