Fog lamp switch - OEM option out there?
Bumping this thread. I have the switch and harness. The harness has a number of ends (some round, some blades). How does one figure out where all of these connect?
The entire harness is laid out in the above pic.
The part to the left seems to be the part that goes under the dash.
The rest of it goes under the hood, I think.
Above, my assistant is pointing out what I think are the two ends that connect to the fog lights.
Above is the only place where the switch will connect to the harness. It plugs to that green connector.
I'm not sure what that loose doohickey is but it fits that connector that it is sitting next to.
Above, my assistant is pointing to another loose thingy that will connect to the other connector. The other device here is a fuse with a snap-on cover.
Where do these ends connect?
Close up of the ends.
Here is the fog light end. There are two wires here. If my fog lights don't match this connector, I assume I can snip these off and crimp to the fog lights. ??
You have access to those? Want to hook me up with a handful? That is the same number I tried locally to no avail.
I'd also want a price on the harness which I believe is 00016-32230-01. LMK
@cruiseroutfit did you ever get these? how did they work out? looking for a clean factory look for adding some lighting to the new truck.
My TJM front bumper fogs came with one. Try looking at what they have to offer. Looks just like the switch on the far left of your pic.
Hmmm... My TJM T13’s fogs are controlled via the stock switch on the steering column stick. Aren’t yours also?
Yes, I ordered a few for my build from Onur. I don't know that I have any left but can check.
  • Like
Reactions: dmc
Are you able to use them in high beam and low beam conditions?
This is interesting . I need this and a FJC version for adding lights to my FJC
Oh... now I see what you’re after!
No. And it’s annoying that they don’t stay on...because the T13 fogs actually cast a very usable, wide side light. When they went in...I was hoping for a solution for that. Would love to find a work-around that keeps the stick control...but keeps it on with brights.
My LED lows do, at least, stay on with my highs...but no fogs. Got a solution?? 😬
