FN Wheels Rock Warrior
New Mexico
I'm a huge fan of the Toyota Rock Warrior wheel, however we all know Toyota no longer makes them. Dustin at FN wheels has reproduced the RW wheel so I had to get a set. I went with FN RW’s Bronze 17x8.0” +45 wrapped with Toyo RT Pros in a 38x11.50R17, they also produce the wheel in a 17x8.5" +35mm and 3 different finishes. These are fully forged and beefy to say the least, heavier bead lips and oversized rock ring bolts that are easily sourced. I'm running these on a Tundra but think they would be a great addition for any of the 5x150 wheeled Land Cruisers.
Looks good, are these the same wheels that Tinkerers adventure Co-engineered?
Glad you like the wheels. 👍 The short answer is no, these are not the same wheels as Tinkerer's Adventure's wheels. Please allow me to elaborate below.
I've communicated with Kai (Tinkerer) a few times over the last year, but such as it is he was already working on getting a "one-off" set of "true bead lock" wheels done for himself before we spoke with each other. I am familiar with the manufacturer that he used for his wheels, and we are not affiliated with that manufacturer in any way.
Tinkerer had his wheels made in a true bead lock form, which isn't something that we wanted to offer in our FN Wheels Rock Warrior wheels since true bead lock wheels are finicky, require extra maintenance / attention, and most importantly - true bead lock wheels wouldn't be DOT / street legal. Our FN Rock Warrior wheels have ribbed bead seats, which are an extremely effective alternative to off-road only bead locks. With ribbed bead seats you get substantially better bead retention compared to standard bead seats without the need to worry about precisely torqueing bolts to prevent your tires from going flat while driving on the street like you would with a true set of bead lock wheels. If your wheels are going to be dedicate for 100% off road use, then a set of true bead locks would be a great upgrade. If you plan to drive on the street with your wheels, aside from legality issues, a set of true bead lock wheels would likely cause unnecessary head aches. For what it's worth, we also designed and engineered a true bead lock, "off road only" version of our FN Rock Warrior wheels. We've just decided not to produce an off road only version because we didn't think we'd sell enough to justify a production run at this time
Also, I am not sure about every precise engineering detail behind Tinkerer's wheels (we didn't discuss minute details), but he is an extremely intelligent, thoughtful and thorough guy. What I do know from our conversations is that we came to similar conclusions about the strengths and weaknesses of the original TRD Rock Warrior wheels. We both agreed on the need for taller safety bead humps and most importantly the need for stronger flanges since the OEM Rock Warrior wheels have abysmally small flanges. I actually wished that the flanges were addressed in Tinkerer's earlier videos regarding fitting 37" tires on a Tundra, since a lot of guys watched his video, installed 37's on OEM Rock Warrior wheels, and then had issues cracking the wheels at the flanges. The OEM Rock Warrior wheels are too weak to handle 37" tires, particularly on heavy vehicles like the Tundra, Sequoia, Land Cruiser 200 or LX570. There have been a number of OEM Rock Warrior wheel owners who have bent or cracked their flanges with 35's, let alone 37's. Our Rock Warrior wheels were engineered and tested to handle the load and stress that larger tires exert onto the rim.
Another difference between our Rock Warrior wheel and Tinkerer's wheel is that our primary focus was to incorporate improvements to the original wheel while maintaining as much of the original design as possible.
I'm personally a huge fan of the appearance of the original Rock Warrior wheels, so I really didn't want to change any part of the design other than that which was absolutely necessary to increase strength or improve functionality. We tried to maintain the original draft angles for the spokes and spoke windows as much as possible. You can install OEM center caps in our wheels. Also, our rock rings are 100% compatible/interchangeable with the original TRD rock rings. The only difference is that our rings use a much more common M8x1.25 hex fastener as opposed to the original M8x1.0 Torx fastener (which is impossible to replace if you lose).
Tinkerer's wheel would be more of what I would call "inspired" by the Rock Warrior design. Aside from making his wheels as true, non-street legal bead lock wheels, which requires a totally different ring design, he also made some stylistic changes to the spokes and to the overall profile of the wheel. I believe he explains this as partly for cost cutting (reduced machine time) reasons and partly because he wanted to impart some of his style preferences into his wheels.
For example, here's a side by side picture that I took of our wheel with an OEM TRD Rock Warrior wheel:
I hope that he doesn't mind, but I took these screenshots from his YouTube video since there isn't a clear picture of his wheels on the internet at this time.
Tinkerer's wheel:
FN Wheels Rock Warrior forged wheel with TRD center cap:
Tinkerer's wheel with TRD center cap:
I think what Tinkerer did with his wheels is super cool, and his wheels would be great for someone who wants a dedicated off-road only set of true bead lock wheels that were inspired by the OEM Rock Warrior design. We just had something slightly different in mind with our wheels. If there's enough customer demand for off road only, true bead lock wheels then we can produce our design in a true bead lock from as well.
I'm sorry for temporarily hijacking your thread @n0rth ! I just wanted to make sure to get a thorough explanation out there before there was any speculation about the two wheels being the same. :)
Any plans on offering a 17x8 with 6x5.5 that works with manual hubs? Looking at rim options for when I need to replace my tires next year on my old Toyota.
17x8" in 6x5.5 (aka 6x139.7mm): Yes.
A version with a center bore that is compatible with manual hubs: Maybe. In order to do that we would have to change the center bore design by removing the flange for the flat center cap. This would be necessary so that your manual hubs can pass through the center bore of the wheel without interference. You wouldn't be able to use a center cap with the wheels.
Our production minimums for the forged wheels aren't too high. If we could get a group of 10 to 15 of you guys with manual hubs who want us to make these Rock Warrior wheels we can make it happen.
Thanks for the reply, definitely don't need any bead lock wheel for my setup.
You're welcome! Thank you too!
We did a design for a true bead lock version as well, but there's just such a limited market for offroad only bead lock wheels that we don't plan to produce them outside of a possible special order / group buy for customers who absolutely have to have true bead locks.
Our Rock Warrior wheels still have some serious improvements to the safety bead hump and the bead seat itself. The original TRD Rock Warrior safety bead humps are/were super tiny, so made sure that our wheels have taller, stronger safety bead humps as well. That alone is a huge improvement over the original wheels, and for the majority of the people will be sufficient when offroading.
There's also a cool design that BFG patented back in the 1970's that's now in the public domain for ribbed/barbed bead seats for better bead retention. We used elements of that design and added ribs to the bead seat to help keep the tire from debeading when deflated and under high lateral load (i.e. airing down while rock crawling). This, combined with the taller and stronger safety bead humps are huge upgrades that don't require the added weight, maintenance and hassle of "true" bead locks (not to mention that true bead locks are difficult to make street legal).
Ok this is cool.
I’ll have to search the net for rough pricing
Current pricing as of August 2026 for our 17" Rock Warrior forged aluminum wheels is $550 per wheel + shipping. That includes one forged 17" Rock Warrior wheel, one forged, removable rock ring (polished and clear coated), and one billet aluminum center cap.
If we make the wheels without the ring the cost is roughly $110 less per wheel.
If we make the wheel with a 106.2mm straight through center bore, i.e. cap-less as you require for your manual hubs, then the cost would be a little bit lower as well.
Can the offset be changed on a custom set of wheels? Curious more than anything.
Our minimum production requirement for an offset change is 48 wheels. I can probably get that down to 32 wheels for the forged wheels, but a one-off set (no pun intended) with a totally custom offset wouldn't really be something that we can do for a reasonable cost. The setup and machine time would just be too cost prohibitive.
What width and offset are you looking for exactly? I'll let you know if we have something in the works that isn't too far off, and/or we can always try to see if there are 6 or 7 other customers who want the same specs that you want so that we can get the wheels made for you at a reasonable cost.
Any plans for TRD repro center caps for the RW or RW clone wheels?
Yes sir, we made a batch of billet aluminum (not plastic like the originals) reproduction caps. The center caps are interchangeable between our wheels and the original wheels as well.
Here's a thread started by another forum member back in February of this year
*The price for a set of center caps might be subject to change in the future.
I don't see the RW wheels on the site, how do I order?
Thank you! We'll have them on the website very soon. The product page is almost ready to go live. In the meantime please e-mail us at FNWheels@gmail.com, call (951)735-1100 or call/text my directly at (714)390-9387.
And is it possible to get a custom powdercoat color? Thanks!
All of the wheels that we have in-stock right now have a factory finish. We have gunmetal, matte black and matte bronze in-stock. If you'd like us to refinish a set for you in a custom color we can do that, but we'd have to know which color you would like so that we can get you a quote. Just let me know what color you'd like. 👍
