Flywheel/Clutch Inspection cover
Quick question all. Does anyone know a part number for the U shaped seal that sits on the flywheel inspection cover. Mine was brittle and totally fell apart while pulling it off to replace the clutch. Also, it appears that the rest of the sealing of the cover is just a generic rubber/foam tape, what have you used here? Thanks!
Use adhesive lined foam for the clutch inspection cover. The original Toyota gaskets are NLA.
I used this stuff from McMaster Carr and it has held up great after two years & counting.
It's cheap, easy to apply and can be replaced easily if it gets gross in a few years.
