Flushing the tranny
Bonsall, CA
I have read the FAQ post on changing the transmission fluid. Link below:
https://forum.ih8mud.com/showthread.php?t=19299
Basically the idea is to put a funnel in the tube where you check the fluid level or suck new fluid through one of the tranny radiator hoses while the other hose pumps out the old fluid.
My doubts:
How can anyone convince me that this method is really good. From my understanding the metal tube (where you check the fluid level) leads to the ATF pan. The pump also draws fluid from that pan. Is't it a situation where you put new fluid and it gets sucked out right away? In other words: new fluid enters the pan, mixes more or less with old fluid and gets sucked immediately through on of the radiator hoses into a bucket.
And what happens when you fill through one of the tranny radiator hoses (while the other one goes into the bucket). Is it a cleaner method? I would really like to avoid mixing new and old fluid. Which is the best method to ensure sucking new fluid and letting out only old fluid?
And my final question. I will need around 18-20 liters to do the flush. I have two products (which is best?).
- Castrol Dexron III ($10 per liter)= $180 total
- Mobil ATF 220, what the hell is this? ($6 per liter)= $108 total.
I am tempted to take the cheaper route but I have only dealt with Dexrons so far and not with some kind of ATF220.
Any comments greately appreciated.
Only use Dextron III or Dextron IV (which includes DIII as part of its approval). Different automatic tranny fluids have different friction vs. temperature curves so it is important to use the proper one.
A complete fluid change is really overkill unless the fluid is fried or in very poor shape otherwise. Instead, just do a drain and fill (6 quarts if you let it drain for several hours) every 15k miles or so.
i did a flush a while back and have since rigged a bypass filtration system to both my cruiser and runner, i use the same fluid and the same detachable filter setup for both
I have done the full flush method you've described on my 4Runner and it worked perfectly. I think of it like this: Yes the tranny sucks fluid from the bottom of the pan and that's where the filler leads to as well. If you fill a straw with mud then put it into a small glass of water and start sucking up the water immediately how much mud have you avoided swallowing by time the water hits your mouth?
The biggest drawback short of having remote start (as I do) is that you'll really want someone to start and shut down the engine for you. I extended the line exiting the cooler with some clear hose and a fitting. Then I started the engine and started refilling like a monkey on crack (have all the bottles of ATF opened and ready to go). As soon as the fluid which was clearly visible in the hose went from brown to bright red I shut down the engine.
I use a 5 gal. bucket for a drain pan. The entire procedure takes less than half an hour.
ive been doing it about 6 quarts at a time, worrks easy and i have noticed the color getting brighter red each time, plus it only adds about $20 each oil change
So from what you said so far doing a full tranny flush is the way to go. I am still not convinced on the mixing of old and new oil. I will try to look at EPC or FSM and find out which tube goes where. If anyone can still clarify this I would be grateful.
I will try to look for the Mobil 1 ATF
I've heard as well as many othere's QS has a very bad rap mainly due to the fact (as told to me by the bulk oil company I worked for's manager) QS's (some years ago) base is was poliester and not oil. Like (but not oil) poiseter base paint is not oil based.
IMO stay away buy the best Quality matirial with the best Quality manufacture.
I'ts got the best/highest Quality part's doesent it?
IMHO It should deserve the best.
IH8W8
IH8W8
This is a twist on an old wifes tale. It has to do with removing parifin from basestocks wasn't correct 30 years ago, and still isn't today. There is very little difference between name brand mineral oil ATF, whether it be Pennzoil, QS (same company), Shell, Chevron, Mobil, Valvoline or Castrol.
There is no problem with using any quality mineral Dextron III fluid. This is what the vehicle came with and will work just fine. Synthetics give a little extra margin of safety at the limit and allow for longer change intervals, but that is about it for their advantages in ATF. Since you are in Europe, why not use easier to find brands like Shell, Elf, Castrol, etc?
I also have the choice of Elf or Castrol but they are more expensive. I need to pour around 18 liters in the tranny probably and the overall prices are the following:
1. Quaker State ATF = $120 / 18l
2. Castrol ATF = $192 / 18l
3. Mobil synthetic, I don't know but it won't be cheap.
So I decided to go for normal ATF as I don't do any heavy towing or other extremes. The rig is mostly a DD in a moderate climate.
But if you say that I can buy Quaker State ATF and sleep well, then I'll do it, thanks.
As long at it is a Dextron III you are fine. Just to note, the flush is really overkill. Just do a drain and fill which is more than adequate.
Well, I am thinking about whether to do a flush or just drain. I bought the truck 2 months ago and it has no information on the ATF fluid change so I prefer to stay on the safe side and change as much as possible and have peace of mind for 20-30K miles which would mean three years of my driving.
I will spill some ATF from the dipstick onto a paper towel and compare it to the new ATF, maybe it will shed some light on the condition of it.
