I plan to replace my leaking radiator soon but before doing so I want to flush out the cooling system. I have done lots and lots of reading on this site and there is plenty of great info. From this info I have devised a plan and want to run it by the experts on this site as I am no expert.
1st of all I want to keep it as simple as possible without any fancy rigs/setups but I do want to do my best to get out the old fluid.
1a - Drain the radiator via the petcock.
1b - Drain the engine block but I'm not sure if I'm able to get fluid back in because at idle the engine never gets above the 180 degree mark required for the thermostat to open. (from my research on this site)
2 - Refill radiator with distilled water
3 - If I do NOT do 1b then I will drive her so she can warm up above 180 so the distilled water in the radiator flows into the block.
4 - Repeat 1a, 2 and 3 and flush 5 times.
5 - Installed new radiator and fill radiator with Coolant. (anyone know the capacity of the radiator itself?)
It seems flushing the engine 5x is extreme (I plan to have 20 gallons of distilled water on hand) but I think the more you can flush the better it is for removing dirty coolant from the heater cores without tapping into those lines.
Also been doing some research to keep my garage floor nice and clean while draining fluid and my solution is a feed bucket. I purchased one from a tractor supply store and they are big enough to catch most of the liquid (2 feet x 4 feet x 10 inches tall ... capacity is 15 gallons)
Any feedback is greatly appreciated. Thank you.
