- Joined
- May 9, 2007
- Threads
- 7
- Messages
- 18
I am swapping out diff, ATF and coolant on a 2016 and 1995. I know I am going to get a lot of variability, but what is the consensus on brand type? Thanks!
Really appreciate the time it to you to knock all that out. Covered my list and then some! Thank you!Chevron Delo 400 XSP 15W-40 engine oil (lower viscosity in very cold weather, check the owners manual)
Mobil 1 or Valvoline Maxlife for ATF and Power Steering (some people use Hydraulic Fluid for the PS).
Mobil 1 75-90 for the gear boxes
LiquiMoly MOS2 Gear additive for the gear boxes ie: Diffs (except Limited slip type) and Transfer case
Valvoline Palladium 3% Moly grease for the steering knuckles (and CV joints/Birfields), driveshaft slip yolks, and U-joints (or Mobil 1 grease for the U-joints)
Mobil 1 or Valvoline Palladium grease for the wheel bearings (ie when you do the front axle/rear axle service and repack the wheel bearings)
Toyota Red for coolant (never mix different types)
Valvoline Synthetic DOT 3/4 brake fluid. Important to ensure the reservoir cap is snug. Flush the system regularly (replacing all the brake fluid every couple of years)
Spark plugs: Iridium type last longer than standard IME (eg: Denso Iridium TT)
**IMPORTANT**I am swapping out diff, ATF and coolant on a 2016 and 1995. I know I am going to get a lot of variability, but what is the consensus on brand type? Thanks!
