Fluid leaking under front Axle?
Palmer Divide, 7110ft.
It appears I have some gunk build up along with a little bit of fresh fluid on the underside of my front axle, any ideas what might be causing this? Here is a pic. Also I live in Colorado Springs/ Denver area, any good repair shops you guys can recommend?
It's either the upper oil pan or the rear main, both aren't fun. If it's just a drip leak, I wouldn't worry much about it, it's an expensive fix to reseal. If you need it fixed, take a day trip over to Slee in Golden, he'd be your closest pro.
The picture was taken from the upper middle of truck looking forward. The "fresh" fluid is on the differential, brownish. Not a lot of it since I have not had any spots on my garage floor, just a small leak.
Think I have the same issue?
I might have the same issue with mine? But mine dosen't look as bad. I cleaned every thing off underneath to get a clearer shot at where its comming from. On mine it looks like its coming from the inner top area between the tranny and engine block. the area if you remove that little dust sheild ? Drip is hardly notiable but if it gets worse def going to wana get'r fixed. Any one know of or trust any of the mechanics around the Santa Maria Area? 93455
That's not the differential you've taken a picture of. That picture is the point where the engine and transmission bolt together, commonly referred to as the bell housing. As FZJFillmore said, you either have a leak where the upper oil pan meets the real main seal retainer, or the rear main seal itself. Very common leak, lot of disucssion on it out there if you want to search.
BTW, what oil are you running? My leak all but went away when I switched from Rotella Synthetic 5w-4o to Chevron Delo 15w-40.
:beer:
Rookie2
Looking at the maintenance records the previous owner used 5-30 Penzoil I think. I read on a number of other threads that people here like mobil 1, should I go with 10 or 15w and is synthetic recommended? Truck has 147,000 miles.
Kind of hard to tell from this picture. You need to find the highest place on the engine that is wet with oil and that will be where the leak is. Mine looked just like that and it was the valve cover. I had three bolts to the rear of the cover that were loose, tightened them up, problem solved.
Like others have said, if it's just a small leak (and it's not something simple like I had) then you may want to wait and get it fixed.
Sum,
Synthetic oil is thinner compared to regular so you'd see more of it on your floor if you are leaking, as in your case. Rookie shifted from synthetic to regular 'fixing' his oil leak problem.
Sounds like you're on the light end to begin with. Might give Delo a try. It's a good oil, probably as good as can buy that's not synthetic.
Kind of how it went down was, I had been using the Chevron Delo and had no problems other than the concern that it may be a little heavy in the winter. Wanted an oil I could use all year round so switch to the Rotella synthetic after all the good things I'd heard. During the time frame of two change intervals with this oil, I developed leaks/seeps at three locations... valve cover gasket, oil pump cover and rear main. Replacing the valve cover gasket, no biggy, needed to be done. But I wasn't so quick to tear into the other two. Decided to switched back to Chevron as much as anything to see if the leaks would stop, which they did.
Obviously they're not "fixed", but I've been down that road before of spending 3 days tearing into an engine to fix a oil seep. Let's just say it's going to have to be more than a seep (meaning it doesn't accumulate enough to drip on the floor) before I go down that road again.
