Just ordered a front floor pan, rear floor pan and rear sill. Drivers side is nearly gone, passenger side is muck better, below fuel tank is not to so go. Rockers look good. Rear pan could stay but rear sill has to go, and so goes the rear floor. Wheel wells are fine and rear qaurters might stay. This rig sat, I guess it just held water under floor mat. Floor mat even looked ok.
What I am thinking is replace forward pan now still on frame. Then cut out rear sill on frame. Then decide on rear floor? I will then remove tub for media blasting. This frame looks real straight to me. Seams like the best way to keep things line up. If I pull the tub first I am afraid I will spend a lot of time trying to line things up and time making a jig to hold everything in place.
I will search all the frame off threads. But what about this direction on my rebuild?
thanks Andy
thanks Andy
