floor pans
Everett, WA
Looking to hear from others that have used a liner product. Would you use again or just paint.
My interior floor pans and under the gas tank need some clean up. I can't make up my mind if I should repaint the floor or use a liner product
Ive been considering what to do once my floor is repaired. I think after reading around on here I will por 15 it then use a good and correct primer i forget which, then spray paint then maybe do a clear coat. From the threads ive looked at using some type of liner is frowned upon as it can just cover up the rust and let it spread un-seen until its a bigger problem. But being under your tank you won't be able to see as well anyway... hm that is something worth considering cleaning up really well, using a rust preventative product and then putting a liner on for more protection
