Floor it, and nothing...
Turning at time of issue may have nothing to do with this. If transmission or ABS RPM should go up. If gas starved I'd expect some missing or sputtering.
I didn't think common after 99, but sounding more like limp mode.
I'm leaning towards TPS, AAPS or IAC along these lines now.
You have a "throttle cable" on your 2000 BUT it's not what operates your throttle body, you are still throttle by wire... I think after 2001-2002 they did away with the cable completely... I would first check the wires/connection to your TPS usually you can stop and restart the engine and the issues will go away until it completely dies
Have you read the ecus for fault codes, I would start with this. How long does the vehicle coast for, is it just a few seconds or do you need to come to a stop to reset it.
