Flange or Pinchweld rust bubbles
nw montana
Looking for opinions on solving this problem. First restoration I did was a 40 in 1990, wire brushed the heck out of all joints. Heavy paint and to noones surprise paint bubbles within 5 years. So then re wire wheel , repaint and heavy undercoating to underside to limit any air or moisture attack from other side. now just starting to see bubbles at 12 years...
Next project, 45, used a aqualu tub and bed to specifically stay away from pinchwelds that might bubble up later. on the steel doors went to all the trouble to take the skins off the doors so I could address the faint rust in the joints and seal them correctly. This was very labor intensive but I feel like I will be better protected down the road.
As I start a 55 project I am going to have to deal with a lot of seams again. no way can I take all these apart. This is to be a DD and my plan is to sandblast carefully inside and out then use POR15, all hidden seams then undercoat bottom, herculiner inside and I feel pretty good about that.
My question is the visible seams like the roof. What are some options that will minimize the chance that bubbles will develop in the outer visible seams?
Did you use an high quality etch primer? I have been told this makes a huge difference, but I'm not an expert. I have used POR and tested it on heavy use tools like hammers and stuff, then let them sit out for a "rust test", short durations now mind you. Stuff seems pretty good but it will peel under certain conditions, I've noticed quite a difference in it's quality when not using their rust prep solvent (acidic zinc phospahate stuff). I use the solvent for preping most everything I paint with any rust, por or not. I'm put off by the product by it's cost though, it you have never used it make damn sure you buy only what you need and use each can asap once it's been opened, don't leave anytrace behind on the lid seal or you will never reopen the can without a punch!
I would talk with someone who restores high-end automobiles for advice on the best products and methodologies. GL-Junk
As you stated rust has to have moisture to spread. If you can seal the joints completely they won't continue to rust.
I read somewhere of a person restoring a car that built a room where he could control the temps and humdity. He put the car in the room and keep the humidity as low as possible at all times. All the work on the car was done in this room. He stripped the rust as much as possible then used a torch to heat all areas he could not reach to drive any moisture out of the rust in the seams ie rendering the rust inert. Then the car was sealed, primed and painted in the same room. He never saw rust in this car again. YMMV :-)
I would suggest before sealing any seams that you use a rust converter like rust-mort. I have used this stuff and like it. It converts the rust, turns it to a black color, weird, it bubbles when you put it on the rust. Then I would cover with something like zerorust and then primer/paint.
Noah
thanks for the advice will look for the rust mort
