FJ80 Not idling well
Boise, Idaho
I just bought a 92 FJ 80 and replaced all of the plugs with Bosch, new wires, both O2 sensors, and checked out the mess of vaccum lines as best I can and for some reason even while it's warm it will idle at 500 RPMs and sometimes just a hair below and other times it's around 8 or 900 RPMs. But mostly it's idling at the lower number and I was told not to mess with the idle control and the only other thing I can think of is a vacuum line... any ideas?
Thank you
Mine did that. It turned out to be the accelerator cable. @ 20 years old it just got sticky. I replaced it with an OEM one and all is back to normal. If you are experiencing intermittent idle RPM's I'd check it out.
When it is idling erratically try pulling/lifting the accelerator pedal with your foot. If it fixes the problem you know the culprit.
mine has been doing something weird also. I just put a snorkel on but cant remember if it did it before but the rpms will raise for a few seconds then lower then repeat. would it have anything to do with disconnecting the battery? is the computer re learning?
Just figured it out. Took the throttle body boot off and cleaned the throttle body with some carb cleaner and made surer to open athe flap and clean as far as I could in there as well. Put boot on fired up, ran rough for about half a second so I gave it some gas steadily for a moment, let off and it's idling right at about 800 like it should be. Turned it off and fired it right back up and same thing.
The battery can weird out apparently from what this toyota shop told me and they're the ones that tested my rig for the O2 sensor and it's kind primitive how they test em but he said a combination of that, the new O2 sensors and the disgusting throttle body is likely what contributed to it. Personally I just think it was the gross throttle body because it did the same idle crap before I replaced the O2 sensors
Thank you I will keep that in mind of I have any more issues. Honestly the cable looks fairly new.
Also I didn't just spray carb cleaner in there I used a rag to do the part before the flap then sprayed the flap in there and cleaned again with the rag. If you drown it in carb cleaner you're going to have a hell of a time starting it afterward from what I understand.
Is the intake hose cracked?[/QUOTE They hose ended up cracking after I fixed the issue with the trottle body and cleaned out gunk.. that flap inside the throttle body stuck open as I was driving down the street causing the motor to Rev like crazy and for me to lose my breaks. I had to turm the cruiser off and coast into a gravel driveway with my e brake as my only break. All happened because that flap inside didn't get cleaned unuff by yours truly.. live and learn. Runs perfect not after it was cleaned properly
So my fj80 was doing something similar. After hours of reading forms, two diagnostics, replacing all the obvious components and parts, nothing I could not figure it out. I was doing some work on her (decided it was female because it gets all my money and it's so hard to figure out what's bothering her) when I removed the battery box to make room for working on it. Under the battery box I found this foam looking giant o ring thing. It looked like I could set my beer in it and hold it from knocking over. Took me about 2 min of thinking to realize it was the rubber boot that seals the air filter to the top of the air filter box. The previous owner when replacing the air filter didn't put it back on. It completely fixed the idle problems. Took just over a half of a tank of driving it around for the computer to relearn everything.
