FJ80 Noob
Austin, TX
I recently rescued a 95 from a field. It had been abused (zero maintenance) on a ranch for 5 years, then sat for 2 more before I snagged it. Amazingly enough, after being parked on an almost empty tank for 2+ years, replaced the battery and added 5 gal of fresh gas and it started up (ignition cutoff relay drama aside). It smoked pretty bad for about 30 minutes of runtime (and an oil change), then cleared up and passed emissions testing with great numbers.
So the bad:
1) had a bad mouse infestation, mostly cleaned up and defunked.
2) had aftermarket alarm that acted up, had to remove that. Caused a lot of drama trying to get it started in the field.
3) both axle seals leaking
4) Think it's drive shaft ujoints, but possibly birfs have a nasty 30mph vibration
5) a bushing somewhere is clunking pretty bad in the front end
So I have a bit of work, and a lot to learn.
Welcome to MUD! :flipoff2:
Good luck!
Chasing driveline vibrations is a massive headache. Start with balancing wheels (cheapest) first, then move on to U joints and such.... I chased one forever and figured out it was the parking brake engagement mechanism grinding on the driveshaft..
AWESOME!
A cheap/free check for the u joints is to lock the center diff (either with the button if you have it or by putting it in 4Lo then pull the fuse then take it out if 4Lo) then remove the front drive shaft and see if the vibration goes away. Repeat with the rear driveshaft.
Remember to scratch a mark on the shaft and flange to make sure you line it up correctly when reinstalling.
AWESOME!
Thanks!
Also your tire could be square or serious flats, I would look there first, and then look at the drive lines, I am betting on tires I would probably just toss those since they sat for so long . Oh BTW welcome to MUD:flipoff2:
It's also possible that someone before you "rebuilt' the driveshaft and got it out of phase. Search for it, test your 'Mud skills.
That's probably for later, but it could be it.
Welcome!
Neither of these things looks right. :)
AWESOME!
So new to me set of tires and rims off a taco fixed the old tire problem. Pulling the front driveshaft and test driving it with the diff locked and the fuse pulled told me the front axle is good, just the bad u-joint on the drive shaft.
