Idles around 800. And i hear air/vacume near the TPS. Yes, i had it unbolted a while back. Guess i can try the butane trick to see for vacume leaks.
I have yet to down load the FSM and go through the procedure. Although it idles pretty steady now. Another strange thing when i remove the oil fill cap when running the engine dies. The idle drops down to a studder and then it dies.Just to make sure, after you unbolted the TPS, you re-installed it correctly using feeler gauges and followed the FSM procedure? If you're off by a few thousandths, the truck will not run properly.
Is this normal? I have never had an engine do this before.
