FJ80 Intro
Dallas, Tx
Longtime ih8mud stalker. Love Blanton‘s Bourbon, from my home town. Just retired, empty nester ready to go build my over landing FJ80 rig. Im at ground zero. For a noobie I’m a bit of an old school purist. I know I want FJ80 with lockers. Only LC, no LX. No engine swap for me. But I would add a TRD SC. I know I’m chasing the holy grail, I’ve been looking for a couple years. I will probably end up with a 100 series that I add aftermarket lockers until I find my FJ80. Ready to get going, I’m 60, and the clock‘s tickin. I hope I’m putting this in the right location. Just trying to follow forum instructions. If not please redirect me. I don’t want to make a bad impression and I’m coachable. Thanks in advance for all the help.
Welcome bourbonator.
Your in the right spot. Keep your eyes peeled here and on marketplace as good ones still pop up but go fast these days.
Welcome! And like said above keep an eye out here, as well as FB Marketplace, also post on the Wanted / Selling side of the forum. You may have to have a murder check out a rig around the states and then have it shipped. There a bunch of threads about what to watch out for as well, rust, locker switches wo lockers, engine gasket replacement tells, etc. read up, ask questions, use the search and you’ll get what you want :).
good luck and welcome!! (Say good bye to your free time and $$$!!!).
Oh and Craigslist!! If that’s not obvious..... look in your surrounding areas too.
Welcome to MUD and good luck in your search. To find a good truck it takes looking at the sources mentioned above multiple times a day. You want to be the first one in line on a new listing if possible.
Here are random buying notes I’ve kept from other posts.
Duncan imports
bringatrailer.com
SearchTempest to search Craigslist nationwide.
SearchWorldMarketplace (same thing, but for FB marketplace).
ih8mud classifieds
Toyota Land Cruiser marketplace FB group
KSL auto
Profit Resurrection
Corsetti Cruisers
Landcruisersdirect.com
JDM Cruiser dealerships
Pre-buy inspection
For importing, do yourself a favor and call Steve Jackson at Land Cruisers Direct. He’s one of the best for a Japanese diesel importing.
Don’t settle for an abused truck. Take the time and wait for the right one. Anything under 200k is a winner, but, not necessary.
Worth paying a premium for no rust and/or an enthusiast maintained vehicle. Check New Mexico and AZ rigs. Rust free and you can find some gems down here for a decent price.
If I was to do it again I’d look in the Southwest and ship it or make the journey. No rust on these old Toyota’s is such a treat. Makes working on them fun instead of a nightmare with broken bolts and stripped nuts at every turn.
I’d want to know if it uses oil & how much.
I’d ask if the headgasket is original or a replacement? If replaced, was the head surfaced & were the stem seals changed?
I’d also want to know the last front axle service done? Look for caked on crap on the front knuckles since they are rarely serviced.
Look for something with documented maintenance If possible, but not a deal breaker. I want to see receipts galore & do a very good inspection from running every last control to doing full lock circles to see if the birfields are ‘clicking’ AKA need replacing or swapping side-for-side.
Lockers are a bonus, but if not locked, you can always add them later. Better to find a good condition, well maintained truck.
Some say the ‘93/‘94 are the best year, OBD1, best engine, best tranny... etc....
93 and up has a good following for aftermarket stuff or OEM.
Also keep in mind that the 93 and 94 model years had the slightly shorter birfields which makes them easier to find Aisin hubs for if you choose to convert to part time 4x4. And they also have the better looking front grill without the space cowboy emblem.
‘95- ‘97 have airbags, full float rear diff, OBD-II, and you can still get engine wire harnesses and o2 sensors.
95+ has a mass air flow sensor, not a MAF meter, so you don’t have to worry about the MAF meter failing.
3FE parts are starting to become scarce. Most of the heater hoses on the 3FE are discontinued 😞
The 3FE is slow, dead reliable, and relatively impervious to neglect. They are slow on the highway, slower on steep highway grades, and happiest cruising in the mid 60 MPHs, which was the speed limit for which they were designed back then.
It's reasonable to expect deferred and ongoing preventative maintenance. Somewhere on this forum is an excellent 3FE tune-up checklist--this is must-do for the 3FE. Sunroofs leak. Cracked dashboards and front seat bottom cushion sidings are common. Also expect to replace rubber things, especially suspension bushings and belts, but also door seals, window runs, etc.
Plan on spending $2500+ to get it baselined (hoses, gaskets, o rings, seals, tools, cooling system updates, knuckle rebuild, fluids, etc). If you get a cheaper rig, budget for more in catch up maintenance.
Here are random some buying notes I’ve kept from other posts.
Duncan imports
bringatrailer.com
LOCALWHEELER.COM – BOISE'S FAVORITED 4X4 MARKETPLACE - http://4buyingautosales.com
ih8mud classifieds
KSL auto
Profit Resurrection
Corsetti Cruisers
80 Series Newbie Guide - Slee Off Road - https://sleeoffroad.com/tech-zone/80-series-newbie-guide/
Pre-buy inspection
(For importing) Do yourself a favor. Call Steve Jackson at Land Cruisers Direct. He’s the only person I would go through for a Japanese diesel import.
3FE parts are starting to become scarce. ‘93 and up has a good following for aftermarket stuff or OEM.
the 3FE is slow, dead reliable, and relatively impervious to neglect. They are slow on the highway, slower on steep highway grades, and happiest cruising in the mid 60 MPHs, which was the speed limit for which they were designed back then.
Worth paying a premium for no rust and/or an enthusiast maintained vehicle. Check the ih8mud classifieds, the Toyota Land Cruiser marketplace group on here, etc.
If I was to do it again I’d look in the Southwest and ship it or make the journey. No rust on these old Toyota’s is such a treat. Makes working on them fun instead of a f***ing nightmare with broken bolts and stripped nuts at every turn.
This is great information right here!
Welcome! I did a WTB thread in the classifieds and had a member reach out with what I was looking for not publicly listed and purchased it. Also had a lot of great leads from other members so may be a good option for you to try.
Duncan imports
bringatrailer.com
ih8mud classifieds
KSL auto
Profit Resurrection
Corsetti Cruisers
Pre-buy inspection
Thank you for the comprehensive list. After baseline assuming I’m not messing with a rust bucket, what should I budget for recurring maintenance. Assume 10k per year highway driving with 1 wk a quarter for overlanding
Great idea. Thank you
Baseline investment is sort of a personal choice...depends how deep you want to go and how much time and money you want to spend. I initially baselined my for camping and family adventures, spending $3000 or so to have a dependable rig...replace all rubber under the hood, all fluids, tuneup parts, brakes, cooling system, filters, etc.
Now that I’m planning trips to the Rubicon and Moab, I’ve re-evaluate what is important to replace to avoid breaking on the trail...rebuilding the steering box, axles, knuckles, suspension, driveshafts, etc...basically anything that gets hammered by rocks.
The deeper your baseline goes, the less maintenance you can expect. How hard you use and drive your truck will affect you maintanence budget later.
Since your plan is for fairly light use, your maintenance costs should be low, assuming your baseline is fairly deep. If you do your own work or send your truck to a shop has a huge affect on how high your maintenance costs will be. Hard to give solid cost numbers.
Do you have a baseline list yet?
Duncan imports
bringatrailer.com
ih8mud classifieds
KSL auto
Profit Resurrection
Corsetti Cruisers
Pre-buy inspection
X2. Good write up. I especially emphasize to not make lockers (or lack of) a deal breaker. Lots of good reliable options on that front. If you find one in Phoenix I’d be happy to look at it for you.
Just noticed this one posted in classified on MUD. It’s in Gilbert. do you know Seller by any chance. Looks like a Good starting point for me. planning on $5K baseline expense.
Don’t know Scott but he is a part of our cruiser club (Copper State Cruisers). This could be a good candidate rig.
