flipped control arms .. !
Yes. And coil overs.
Subscribe
Are you planning on equivalent ride/steer ON-ROAD as the OEM?
In other words, how will it function at 75MPH?
you're on the right track to a killer toyota front axle, just add some longfields to the mix.A Ruffstuff Hi9 housing, 80 knuckle balls and these knuckles would make a really nice 80 axle, and allow you to keep the ABS intact.
Lets see some pictures or at least an engineering drawing. Is this just a thought or something real?
thanks, and these will be happy with an 8" ram.Nice work...I thinks folks can appreciate the need to keep pics on the qt until certain milestones have been met.
Will the steering geometry work with readily available steering rams? i.e. 6" or 8" cylinders?
yep, the rest stays 80. i see no way (or need) to improve the already massive brakes.I kept a set of 80 series balls hoping someone would make hi steer knuckles.
The longfields would be great but the bigger 80 series brakes are what i am after.
I hope if you are going through with this you are making them for the 80 series caliper.
Curiosity is getting the better of me...You wouldn't happen to be billybob13 over on Pirate would ya?
I've been following your thread in the mini truck section regarding the knuckles for a while.
who's running a fj80 front axle, and who wants to? - Pirate4x4.Com Bulletin Board
So are you making new arms as well, or trying to fit mini truck arms (existing arms available) onto the knuckle?
I want to hear more. This dosen't use the ABS sensor hole does it? Most of the people that would want to use these need to pass a safety inspection and need it to work...
the sensors will be relocated since the new arms will cover the area where they were from the factory. a plug will be provided for all the guys who don't need the sensors.I want to hear more. This dosen't use the ABS sensor hole does it? Most of the people that would want to use these need to pass a safety inspection and need it to work...
i think i understood dans question, he was referring to the factory location of the sensor, which doesn't make sense when picturing the arm up there.Answers in post #1.
what about prices???
Do you realize the they are different from the mini/40 to the 80? The 80 is 20mm and the mini/40 is 17mm...
