Has anyone tried using Slee's front swaybar blocks on their 1991-92 FJ80? It looks like it would fit, but it's listed for a '93 and up...is there a difference?
Thanks.
Thanks.
Ironpig has their's listed for 91-97 so I would say yes,
FJ80 Front Sway Bar Drop Kit [IPOR-FJ80FSBD] - $34.95 : Iron Pig Off Road, Toyota Land Cruiser experts
i just use some square tube, and drilled some holes & longer bolts..done.
you bc boys rock.i have never played with this could you school me quikly of the advantage,how much drop or i have been told to remove it or drop it and put a quick disconect in
the purpose of this mod is that once you lift your truck past a certain height, the swaybar comes into contact with the driveshaft. lowering the body mounts using these spacers moves the sway bar away from the driveshaft. theres a member here in the 80s forum thats built up some disconnects. i still run the front, but no rear. im contemplating on just pulling the front all together...
