Fj80 Extended Wheel Base?
So I am working on a project using a FJ80 frame. I plan to fit a utility box on it but need to either hack the box to fit the wheel wells or extend the frame about 5 inches. I am leaning towards extending the frame which would put the wheel base at 117 inches compared to the stock 112 inches. My question to this group is, do you think it would be beneficial to have a slightly longer wheel base for an fj80? What do you think the pros and cons are for performance? I really like the turning radius in an fj80 and am concerned about how much this may affect that.
The purpose of my build is for overlanding and moderately technical trails. No extreme rock crawling or such and I will be running 37" inch tires on it.
Thanks
We extended our UTE project and it definately changed the turning quite a bit. We added 9". You can see that build with link in my sig.
I plan to make a FJ45 later this year, and do plan to add about 6" to it.
Good luck, used to love your beer.
I'm contemplating doing this on that rolled 80 I have, as I mentioned to you a couple months ago, but I'm thinking of 8-12" stretch.
Following
I looked through your build thread a saw how you spliced your frame. Looks like it turned out great. Cool build. I don't want to extend it anymore than I have too.
Following
What kind of build are you planning that you want to add 8-12" for? I must have glazed over your earlier post.
I decided the best way to do what I want is to find another frame that I can cut the back half off of and only have one splice to weld rather than two. So I have started the search for a second frame that is fairly clean to start with.
Where are you located?
Northern New Mexico.
