FJ80 Alternators
W. PA
I'm parting out my very rusted 1991 stock Cruiser.
Replaced it with a 1992 Cruiser. I was excited to have a spare alternator, but the plugs are not the same.
I was under the impression the 91 & 92 were part for part swap outs.
Alternator is pulled from the 91. New regulator matches the 92.
Is this normal?
Toyota made two different alternators between the years. They had a 12V 80A and a 12V 90A. That would be the difference in them
12v 80a: 27060-61091
12v 90a: 27060-61100
Thanks! I don't see that distinction when I google FJ80 alternators.
Bet that has led to a lot of mail order disappoinment.
(The alternator in the '91 doesn't look like the 90A's I see on line. It has the external fan.)
80 amp external fan 1991-mid 1992. Not easily rebuildable.
90 amp internal fan mid 1992 on. Rebuild parts available.
Mounting brackets are different.
The part you have is for the 90 amp alternator.
As a follow up, I replaced the popped headlights, fuses, relay, fusible link, and voltage regulator.
Everything works fine now. Probably a huge overkill, but when you are in the process of parting out, you have all that stuff laying around anyways (except the regulator, which I had to buy). It's just as easy to replace it with known good ones.
I theorize there is no way to blow all bulbs at once unless the voltage is way over 15V.
Any idea of the part number for the plug that goes into the 80 amp early 1992 alternator?
I've been searching here, and all over the internet for over an hour and can't figure out what to order.
Thanks
