Fj73 need some tips for lift my truck
Aruba
Want to put some 35 inch on it
Im running 33 inch right now
How much do you want to spend? Lift kits from Australia start at around $1200AUD and keep going past $2500AUD.
Might be easier and cheaper to go with a spring over axle conversion (SOA)
Ebay Australia has the best and biggest range. Dobinsons Springs are good
Cut the spring mounts off the axel and weld them to the opposite side. Basically your reversing the contact point between the spring and axel. Also I think you need to shift the axel a bit forward to clear 35's. You may need to get a longer drive shaft with a soa too. Anyways, if you have to ask you should probably hire someone.
Hello,
x2.
Shipping costs may be a killer.
A 2 in/50 mm suspension lift can work for you. Dobinsons is a good choice.
You might need to move the front axle forward 1 in./25 mm to accommodate 35 in. tires.
SOA requires care with the shafts.
As noted above, it might be better for you to hire someone or a shop for the suspension change/SOA, regardless of your choice.
Juan
I've got to ask, why do you want 35s? These trucks are super capable on 33s which clear easily. It doesn't really need a tummy tuck like a jeep. Just some armor and quality 33s will go almost everywhere.
