- Thread starter
- #21
Didn't look bad hereDon't know why you didn't just use that body.
i did a lot of cross checking for clearence. probably ran outside with the tape measure about 30 times to look at my 62. the tight section i was planning on using heat wrap of some sort, although it looks closer in the pictures too. i don't think i have any more room on my 70.So much easier to do exhaust from the top. That being said, check floor clearance to the rubber hangars
you have at the back. They look higher than the frame. The floor of the body is pretty close to the frame.
BTW, you'll need heat shield I think along beside that brake line, or is that a fuel line?
I think they used a 4 speed cross member on my conversion, and it rubs on the driveshaft.
No dents, just shiny metal but I still have the sway bar on and I don't push the articulation
to max much.
That belongs to my friend, part of his special projects plan. Possibly being crammed into a 60What's that 12 valve and nv4500 doing in there? Does it need a new home?
^ Eagle eyes Dan on the prowl! Awesome.
Betting on beer capsIs that a dime on the floor?![]()
