- Thread starter
- #21
Thanks - Thinking I'll start with the compression check. It's been a week since i got it back. Maybe I'll do another oil change to see if there is any coolant in the system. I'm not losing or leaking anything under the car. There is a little white vapor from the exhaust on startup but it quickly dissipates.unlikely that any of those repairs would introduce coolant to the top of the head. At least I can't envision that, if for some reason while the value cover was off there was a spill of coolant then that should have been dealt with. You need to address this because coolant in the oil or vice versa is going to cause you some problems with bearings...or other things. I'm betting the cylinder head is cracked base on internet pics.... Stop driving the truck or running the engine. The shop doing the work should let you know if they spilled coolant and they should have done an oil change. You need a compression check and likely some other testing to check where you are with regard to the cylinder head.
