Fj60 transfercase options
Washington
So, at some point someone put a 10 spline transfercase into my fj60. As well as an sm465. Anyways, i'm putting an nv4500 into it and now is the time to change up the transfercase as well. What are you guys running in yours? What do you suggest? I have the original front and rear end and didn't plan on changing that anytime soon. So it will need to have the rear offset.
Options:
The 10 spline I have
Orion
Factory splitcase
What else do you suggest or have?
What’s the rest of the Cruiser look like? What are your goals for it?
Factory case is probably your best bet unless you have some very hard core use case.
As you are buying a new trans to t-case adapter, I’d highly suggest going back to the original split-case. It’s stronger, better shift components and far more high and low range gearing options available. You can source a complete used case or new are available too!
This is a popular option for a new replacement:
