I just finished re-installing my rebuilt transfer case for the second time. I would appreciate some input.
I used these 2 threads which were very helpful:
https://forum.ih8mud.com/40-55-series-tech/188968-split-case-rebuild.html
https://forum.ih8mud.com/60-series-wagons/487813-transfer-assembly-pictures.html
I have one question that will bug me until I get a definitive answer. On the front 1/2 of the case before it is mounted to the transmission, when the front output shaft is pressed onto the new front output shaft bearing, does the shaft seat all the way against the bearing?
I ask this because I had a shop replace that bearing and press the front shaft back in and it wasn't seated all the way against the bearing. I was getting a "growling" sound and some vibration in 4WD, so I pulled it apart and seated the bearing all the way. The growl is gone, but there is still some vibration there.
I used the instructions in the FSM and I assume if the bearing was not supposed to be seated all the way on the shaft, there would have been a step on the shaft or it would have said in the FSM.
I can post pictures if it helps.
