Fj60 running rough need help!
Yeah your right! it is working, but how well?
Have you seen this? or a someone on mud that is good a rebuilding?
http://www.ebay.com/itm/CARB-REPLAC...Parts_Accessories&hash=item4ac7937fe7&vxp=mtr
The part number given on that ebay item (21100-61012) appears to be for a non-USA FJ4x, FJ6x carb (no smog):
http://shop.cruiserparts.net/index.php?main_page=product_info&products_id=33997
My FJ60 USA 2F OEM carb PN is 21100-61011.
For carb and distributor rebuild and other desmog hardware, you can get in touch with Jim C. ( @FJ40Jim ) here on MUD.
This should be his email: fj40jim(at)gmail
and his shop info:
http://www.tlcperformance.com/
I know when I put my carby back together I forgot to connect the solenoid wire at first and it ran real rough, so a faulty solenoid/wiring might cause your symptoms. The issue with the #6 cylinder is interesting though, if valves are good and compression is good I don't know what would cause that. Do you have a timing gun?
Yeah I have a timing gun. I was working towards timing it again last night and as i clocked it enough to even see it in the window it dies?
Did you take a look at the video when i pulled the #6 wire?
Thanks!
Definitely a 2F carb but don't think it is for an FJ60, looks to me to be for an FJ40 which I believe is a slightly different carb. Look up the rebuild series for the carbs on Youtube, think it was Pin Head that did it (from here) and is a great series to go through.
Nice! that is a great series. (didn't finish it yet) but good to know hpw to adjust on my own in the future too.
Thanks
and his shop info:
OK! i will shoot him an email today. Seems like he is full of knowledge on this.
Also thanks for the link for the carb.
not sure if i will rebuild or buy new @ this point.
i didn't see any vacuum leaks on the intake manifold.
Do i need all vacuum hoses connected besides the 2 on the distributor?
only because i have the air filter off now!
Thanks
If you can get the timing mark (7deg BTDC) to align with the pointer with the engine running and distributor advance disconnected and unplugged, then your timing is set properly. You don't have to worry about the distributor gear being off a tooth or so. The orientation of the distributor gear really only matters because the advance diaphragms prohibit the distributor from rotating all the way around. But if you can set the timing then you are OK.
From the picture above, the plugs are connected properly per the firing order (1-5-3-6-2-4).
These carbs look like Trollhole Carbs - yes?
Yeah, I think you might be right, but I'm not sure.
Best thing would be for the OP to directly talk with Marshall ( @Trollhole ) here on MUD. There are a lot of folks who don't rebuild their OEM carb and install a Trollhole carb. I'm not sure what the difference between OEM and Trollhole or OEM and that carb on Ebay/Crusier Parts is...
and his shop info:
Ahh! it just clicked. I have camped with Jim C. before in moab. With Kurt from cruiser outfitters.
Anyways this carb say's non-USA? is that a concern?
thanks
Do you have to pass smog in the county you live/register you vehicle in? My understanding is that that non-USA carb you linked to Ebay does not have the necessary ports to use the USA smog equipment.
So if you don't have to pass smog, then you might be able to use either that non-USA or a Trollhole carb, if you remove the emissions equipment, but I would direct those questions to those folks.
If you remove the EGR stuff, you might also have to recurve the dizzy. Address that question to Jim C..
Here is a .pdf that some great dude here on MUD put together to help walk you through a proper desmog, if you so decide...
Was thinking about this again, and I'm not sure the interpretation I gave you here is correct. In other words, I'm not sure that 'checking the alignment with the engine off' helps you out at all or is even sound logic.
Because you need the static light of the timing light to know exactly when the dizzy is lined up (giving spark on #1).
But the info on which mark does what is sound.
Carry on...2mbb is giving you a good lead...!
Right! i took your advise and checked that #1 cyl was at TDC. It was.
OK. Sounds like ICS is working.
Which emission ports by valve cover? Picture?
this is what i tightened a bit but it was smoking around this.
That is the Air Rail. It is part of the Air Injection System (AI) - pumps air from the smog pump into the exhaust (either at the manifold, or out the down pipe). For information on the AI system, see the Emissions FSM for the 2F engine.
The smoke might be one of two things:
1) exhaust leaking through a hole or loose fittings on the Air Rail
2) burning off of oil/fluids (like PB Blaster penetrator) on the Air Rail as the engine reaches operating temperature (gets hot).
Which do you think it might be?
For overview on replacing the check valves on the AI system, see post #17 in this thread:
https://forum.ih8mud.com/threads/gap-in-exhaust-manifold.822180/
here is the video of it running and the #6 wire being pulled.
In your video, your PCV valve is not connected to to the hose that runs behind the valve cover and into the intake manifold. Not having your PCV valve connected should not effect how the truck runs, but if the port into the valve cover is not plugged, then you will have a massive air leak. You should be able to leave the PCV valve connected and remove the air cleaner, valve cover etc.
I think the PCV valve pulls vac from this pipe...a hose connects the two. If that pipe fitting is open to atmosphere (i.e. no hose) then it will be a source of a vac leak...
Thanks!
I saw the vid, don't know why that would be though. You're sure the valves are good? If you turn the motor to #6 tdc then continue turning over can you see the #6 exhaust valve open and close followed by the intake valve as you get around to a full rotation?
I just placed the valve cover on, but i may try and look at that too..
They seemed to adjust real nice! but could it be the cam? (not sure if that is what your getting at)
Try seafoaming it. I have not read the entire thread, but when i had my gasser I had a similar issue, but different in that the truck would not stay running. After replacing everything under the sun, intake gasket etc i seafoamed it and low and behold, she ran like new.
