Fj60 running rough need help!
We bought an 1987 Fj60 last week!
it ran rough all the way home and during the test drive.
the issue: it starts but runs rough.
i found out that when i pull the #6 wire the RPM's go up significantly.
i do hear an exhaust leak could that cause it?
What i have tried:
i tried timing it.checked wiring order and firing order where correct.
i have adjusted the valves.
i have checked compression. (consistent through all cylinders)
replaced plugs, wires, cap, rotor, coil.
i thought i would try moving the distributor over 1 tooth but it did not help.
It seems like the #6 cylinder is fighting against the rest, but even when i try to time it. It runs the same.
My other options:
buy a brand new distributor?
Thank you for any advise
Any chance you could post a short video of the rough idle and what happens when you pull #6?
Have you don't any adjustments to the carb?
Did you ensure that you are getting spark to all cylinders?
You are sure that dizzy is set properly?
Yeah! that's a great idea! I'll video it this evening. and pull # 6.
no adjustments to the carb. glass on carb has full it accelerates nice, but rough running.
when insuring that i got spark to all cylinders that is when i found that #6 unplugged made the RPM's rise.
Not sure that the Dizzy is set properly but when moving either from all the way advanced to all the way retard. the overall rough running is the same?
Thanks for the reply! I'll post the video later!
If you do a search on MUD for instructions on how to test that the ICS (Idle Control Solenoid) on the carb is working properly, then ruling that out as a cause for a bad idle is a good first step.
Short version of testing the ICS:
1) Engine off
2) Unplug the green connector of the ICS at the carb
3) Turn ignition to 'On' but not 'Start'
4) Reconnect the green connector on the ICS at the carb
If you hear a 'click' when you reconnect the connector, ICS is actuating properly. If you don't hear a click, it is most likely due to a bad ground (it grounds through the Emissions Computer). The mod is to reground the ICS permanently.
Might also check to make sure the fusible links are good.
From the positive(+) battery terminal, follow the lead until you see this (see below).
The Wiring Diagram shows that there are 3 fusible links at that green connector.
To test, disconnect the plastic connector at the far side (away from battery) of the fusible links.
Ground the black (-)negative lead of your voltmeter to the vehicle chassis.
Touch the red (+) lead to each of the 3 contacts on the far side of the fusible links...it should read 12V+....if it does not, that fuse is bad.
Check all three fuses.
If one or more is bad, do a search here in the 60s section for instructions on how to repair/mod...
fusible-link-fj60-jpg.938574
fusible-link-circuits-fj60-from-chassis-body-1980-repair-manual-png.938575
1) Engine off
I did notice the previous owner had changed that solenoid recently. At least it looks newer. I will do both and post the conclusions. Great idea!
Thanks!
"tried timing it". Does this mean you got the timing correct or could not? If you can get the timing mark (the "BB" pressed into the fly wheel) to align with the pointer, then your distributor is not off by one tooth. Timing should be checked with the vacuum lines disconnected from the distributor advance diaphragms and the tubes plugged.
Please also take a picture of your distributor cap with wires including the spark plugs, so we can confirm the wires are connected properly.
Also check for vacuum leaks, etc. The main vacuum port for the brake booster comes off the intake manifold by the #6 cylinder. I suppose if you have a leaking booster or the tubing is cracked you could have a very lean condition at #6.
Sorry! "try" meaning i did get the timing marks to line up, but is was still running rough.
right now the air filter assembly is off of the carb. It is a California fj60? (i would love to de smog, but will wait until it runs correctly now.)
I will post those pic's also when i get off work. and check all vacuum lines.
not sure if i mentioned, but there seems to be an exhaust leak also. I have not tracked that down yet.
Thanks again!
Ok when you look at the carb and you see the level of fuel is it all the way to the top? If so, then you are drowning your truck which is probably part of the reason it idles horribly. The fuel level should only come up halfway on the sight glass. So basically where the sides curve IN is where the fuel level should be, no higher.
I think 2mbb is referring to how well the TDC line (the one stamped on the flywheel) aligns with the alignment mark on the bell housing viewing window when the engine is OFF (not running).
With the engine off (not running) and on flat ground, if you put the transmission in 4th gear, release the parking brake, then you can push/pull the vehicle while watching in for the marks to align.
If you first pain the TDC line and 7*BTDC bb with white finger nail polish, it is easier to see. To access, remove the flywheel cover and paint...
I know when I put my carby back together I forgot to connect the solenoid wire at first and it ran real rough, so a faulty solenoid/wiring might cause your symptoms. The issue with the #6 cylinder is interesting though, if valves are good and compression is good I don't know what would cause that. Do you have a timing gun?
If that is where you fuel level is when you are running then you are fine. That is one rusty ass carb. Might be time to pull her out and clean her up a bit.
1) Engine off
I tested this last night and the solenoid had a click when plugged back in.
It does seem to smoke lightly from the emission ports buy the valve cover?
Thanks!
Thanks!
OK. Sounds like ICS is working.
Which emission ports by valve cover? Picture?
Was thinking about this again, and I'm not sure the interpretation I gave you here is correct. In other words, I'm not sure that 'checking the alignment with the engine off' helps you out at all or is even sound logic.
Because you need the static light of the timing light to know exactly when the dizzy is lined up (giving spark on #1).
But the info on which mark does what is sound.
Carry on...2mbb is giving you a good lead...!
