"if you got some kind of magic website that can help a guy decide something, keep me in mind"
There is Lots of information on this forum about most power steering conversions for your 40.
Saginaw- mounts inside the drivers side frame rail in front of the cross member. Offers the most power assist, for SBC the steering shaft can be a bit tight depending on engine placement, but it fits and people like the assist for larger tires and lockers. Some feel that the saginaw box doesn't provide enough feedback while steering.
FJ60/Scout- mounts outside the drivers side frame rail just in front of the shock tower. Has more "feedback" than the saginaw box, but not as much power. (the scout box is suppose to be stronger). Seems to do well on 35" and under tires. Slightly less issues with steering linkage clearances and SBC exhaust manifolds/headers.
The mini-truck style is close to factory power steering. All the linkages are maintained, and the power steering box replaces your manual box. Should require the least amount of "fabrication".
You can also use the Astro box but I am unfamiliar with it.
BUT you can read about it here:
http://www.ih8mud.com/tech/astro-ps.php
In case you didn't find this link while you were searching...
http://www.lslc.org/common-btwn-chapter/newsletterfiles/LSLC-Jun01.pdf
If you have any specific FJ60 PS ask away.
Bret
