fj60 part out
Status
Not open for further replies.
have a 60 taking up space at my parents house that must go quick. dads threatening to scrap it if its not gone by christmas. i believe ill be holding on to the tranny and transfer case. everything else up for grabs. interior in actually imaculate. let me know what you need and make offer. id love to see someone come pick the whole thing up so i dont have to scrap any cruiser parts.
James Case
Interested in:
Stone shields on headlights
Fuseable link on +battery cable
Are those nerf bars welded on?
where are u at?
swamp60
Interior parts
What color is the interior? I'm looking for a gray center console and some of the trim pieces that go in the door opening by your feet.
Also, the e-brake assembly if it is in good condition.
Thanks!
What year is it? If it has the older (pre 4/85) cross-member, I'll take that and the side brackets on the frame.
I need the bracket on the firewall that the carb linkage goes into. Need the rubber boot on the firewall that the gas pedal goes through.
also interested in the distributor
interested in the Distributor rubber boot IF not ripped, thermostat housing if not rusted and the clutch slave. How much for both and shipping to 91723?
Thanks
sorry guys, i havnt been on in a few days. for those who asked, im located in long beach ms. the cruiser is an 83 model. the step rails are gone already and ill be selling the axles whole.
mel lowe- carb and igniter are yours.
swamp60- stone shields gone,Fuseable link on +battery cable is yours.
OldBeachBob- front or rear side marker lights? had to use one front for my 62.
socketjockey- interior is brown, you got the ebrake if you dont mind the color.
Spike Strip- gotta hold onto cross member for my 4 speed swap in 62. side backets on frame?
Beams37- you got the hac valve
uberFJ- you got the ps pump and ect.
wengejor- you got the bracket, rubber boot, and distributor
ksollinger- you got the passenger side tail light and ac parts
JLH911- ill check dist. boot tomorrow. you got thermostat housing. gotta hold on to slave for my tranny swap.
meat- you will have to explain with the double cardon. not really sure
make reasonable offer on parts. also open to trades for some 62 parts. need intake boot that goes from intake manifold to maf. need fan blower relay, turn signal relay. or any other after market performance or lift parts you may have (extended brake lines for soa).
Two diff x-members: early (pre-4/85) is really three pieces - x-member bolts to brackets that are bolted to inside frame. Later style for tranny with spacer, is a 1-piece that bolts to bottom of frame.
If you're putting a manual in a 62, you'll prolly want the 1-piece for ease of installation. I have one I can trade for the early style if you want... ?
Lemme know.
Status
