the simplest wayi run mine off a toggle switch.
I'm looking at an '82 and '83 FJ60 and may buy one of them.
The person with the 83 said there's not supposed to be a fan that runs after the motor shuts off. The one with the 82 said it runs on a hot day. Is this how they are both supposed to run. If not, what is wrong? Thanks
I don't want to make a mistake and buy a bad LC as I can't fix it myself and have limited resources. I'd welcome anywone with any advice about this situation and the specs on the cars (as I'd hate to brake down on a 2500 mile trip).
Thanks
Vanyoska
ratmoppett@verizon.net
Carb cooler didn't work. Checked here, found sensor way up there under the manifolds and encased in a protective shell of rust and corrosion. Don't think I want to play with that so I went online and found this: Amazon.com: Hayden 3653 - Thermostatic Fan Control: Automotive.
It's an aftermarket electric radiator fan thermostat that's adjustable from around 50f to 150f. Wired it into a hotwire under the dash (I had a switch before I found this) and mounted to a bracket by the fan, stuck the sensor into a vacuum hose clip on the carb, fiddled with the adjustment knob and all is forgiven. Works great for about 30 bucks.
