FJ60 bulbs list?
Metro NY
All of this chatter regarding LED replacement bubs has gotten me looking for a comprehensive list of all of the bulbs, save the headlights, used on an FJ60. I would love to do a complete LED replace all around, inside and out. So far the suppliers have not seemed to be able to come up with that complete kit.
is this list floating around here somewhere?
Thanks
mark
This is kinda what I mean when I say it seems to be tough to get someone to supply a COMPLETE kit...
From what I understand the turns require a special LED flasher... so be it.
What I want is to be able to say: "I want my dash lights to be XYZ color, otherwise all of the lights should be their "normal" color" (that is: if a white bulb behind a red lens is better than a red light then give be the white, otherwise a red)
I WANT ALL OF THE BULBS EXCEPT FOR THE HEADLIGHTS IN A SINGLE KIT. (or at the worst a list of kits that, together, cover the whole vehicle with no overlap.
Can you help?
Can you post this here on mud?
Thanks, Mark
PS: IMO you have too many threads here... why not consolidate to a single thread.... or better yet get a website to link to...
Mark, I am already working on the flasher unit and the dash bulbs and all, you may beat me to it because I am looking for the best quality and price so I can provide the same to mud. Once the flasher search is done then I will do the dash and anything else inside, trying to keep the comprehensive kit under $100 is tough:( also, I have one thread here in the 60 section since the kit came out, the others are reviews posted by akcruiserfreak and klinetime574. Ever since you contacted me a month ago I have been working vigorously to find all items that will maximize the 60 series lighting department. My policy is if there is any room for improvement, then I will stop selling a product until that improvement is made(ie the reverse lights) however sometimes manufacturers do. Ot comply, luckily for me I have been about 50 percent successful at the matter of improving a product. For me it's quality not quantity, that is why although I have the old model reverse bulbs, I want to wait on the newer ones, same with the led signals and led dash components
Also, I will get full pics and specs posted here by tonight
Can you help?
Thanks, Mark
EXCELLENT!!!
I am not in a hurry so I won't be beating you to anything... I was just getting blurry with all of the bits and pieces. I really do appreciate that you are taking the time to do this... I think you will have a very salable kit once you get it all together... Count me in!
And I'd love the option to be able to choose green, red or other colors for the dash lights that are OEM green.
Thanks!
EXCELLENT!!!
Thanks!
Pm sent, mark and I will get this full kit setup and basically have the most comprehensive kit available on mud
maby this will help you with what bulbs are required to mkae a compleat kit. i dont have any regular bulbs left in my truck this is what i used and i got them all from superbrightleds.com. i am verry happy with the results but it took me a long time and some trial and error to get it right. if you can come up wit a kit that includes all of thies bulbs at a decent price im sure you would make alot of people happy.
BULB PART# QTY MODS
stop/tail light 1157-R45-T 2 NO
FRONT/REAR TURN SIGNAL 1156-A45-T 2 NO
BACK UP LIGHT 1156-CW45-T 2 NO
LICENSE PLATE LIGHT 67-W9-WV 2 NO
FRONT TRUN SIGNAL 1156-A45-T 2 NO
PARKING LIGHT UPCB-CWHP30-BA15S 2 YOU HAVE TO MOUNT THE BULB
PARKING LIGHT ALT 67-CW-2W 2 NO
SIDEMARKER FRONT WLED-AHP 15-T 2 THIES TAKE ALOT OF CUTTING TO WORK
SIDEMARKER FRONT ALT WLED AHP5 2 NO
SIDEMARKER REAR WLED-RHP 15-T 2 THIES TAKE ALOT OF CUTTING TO WORK
SIDEMARKER REAR ALT WLED-RHP 2 NO
REAR UTILITY LIGHT UPCB-CWHP30 1 YOU HAVE TO MOUNT THE BULB
UTILITY LIGHT BASE UPCB-FES 1
FOR A WHITE DOME LIGHT YOU CAN USE THE SAME AS THE UTILITY LIGHT
COLORED DOME LIGHT 3710-XHP6 1 FITS BUT YOU HAVE TO BEND THE TABS OUT THIS WONT WORK IN THE UTILITY LIGHT
HEATER PANAL 3022-XHP4 1 NO
GAUGE BACKLIGHT WLED-XLX 3 IT TAKES SOME FILEING TO GET THIES IN THE BASE
GAUGE BACKLIGHT ALT WLED-XHP 3 NO
TAC BACKLIGHT WLED-XHP9-T 1 NO
DASH BLINKERS/4WD WLED-G-120 3 NO
DASH BRIGHTS WLED-B-120 1 NO
CHOKE LIGHT WLED-A-120 1 NO
BRAKE/SEATBELT/CHARGE WLED-R-120 3 NO
CIG LIGHTER/GLOVE BOX 74-XHP 2 NO
DEFOGER SWITCH 24-XHP 1 YOU HAVE TO BEND THE WIRES STRAIGHT AND CUT THE BASE OFF THE BULD AND WRAP THE WIRES AROUND THE FACTORY BASE
DEFOGER SWITCH ON 24-AHP 1 YOU HAVE TO BEND THE WIRES STRAIGHT AND CUT THE BASE OFF THE BULD AND WRAP THE WIRES AROUND THE FACTORY BASE
ps: sorry if its hard to read.
I found this for the standard bulbs... not sure it is right (don't know what the "step/courtesy" light is either)
High & low beam headlamp
H6024
Parking light
67
Front turn signal
1156
Rear turn signal
1156
Tail light
1157
Stop light
1157
License plate
89
Back up light
1156
Front sidemarker
67
Step/Courtesy light
DE3425
Mark, where exactly is step or courtesy light on the 60 series?
i googled the pn and it looks like it a festoon bulb. there are three festoon bulbs in a 60, heater panel, cargo area, and dome light. my moneys on the dome light.
If you go with LED headlights do you still need to upgrade the wiring harness or can you keep the stock wiring? The kit looks awesome, just waiting for the upgraded reverse lights.
truck-lite makes them. too expensive imho and you have to get harness adapter to fit. just do harness upgrade and h4's. you wont regret it.
I have noticed some lists have an 1156 for the reverse lights and some have an 1157 called for. I would like to put some LEDs back there.
Does anyone know which bulb is correct for an 89 FJ62?
Does anyone know the difference in the two?
When going LED I used the same color bulb as the lens it was going under. (And changed my dash lights to blue.) I used superbright and was happy with what they sent me.
I made a point of using different low intensity LED's for the high beam, 4WD, and CHOKE indicators. I didn't want them annoying me at night and they don't dim with the rest of the dash.
For the rear dome festoon I soldered on one additional cap from one end of the removed incandescent to make it long enough to fit in the housing.
I came to the conclusion that changing the blinker bulbs was way more trouble than it was worth because of the required flasher which doesn't fit into the Toyota's socket. They don't run long enough to generate heat and melt the plastic like in the dash. If the lenses are clean the blinkers are bright enough. (I don't use blinkers much anyway. :doh:)
I'll see if I can dig out my order list.
Anybody know the LED bulb sizes of the interior doom light and rear cargo light?
I also have the front passenger marker light out, so might as well replace all for markers with LED. Size?
If there is a site vendor, I'll use them. Thanks.
superbrightleds.com has a good bulb finder on their site.
