forum.ih8mud.com
I was uneducated guessing at +/- 2500. Looking at the different wt capacities, little price difference between the 2000-4000 lb units. Prolly rolling with:Back-of-Envelope educated guess:
5360 lbs GVWR from door jamb
-1900 lbs engine/transmission/transfer
-1200 lbs axles/wheels
-1000 lbs glass/interior
1260 lbs carcass weight~~ Use 2000 lbs as minimum?
I have the Titan, works well.
Much appreciated!I made the trusses so each body mount can be supported. I would not trust just supporting the body at the fire wall mounts and rear most mounts alone and that is all you will get with just the twirler. There are no "specs". I just built the trusses out of 2x2 and 3/4" square tube. I'd worry about bending the body without trusses of some sort.
