Wanted FJ60 Aisan stock Carburetor MINT or better
Spike Strip
Goblin Mode Activated
Fraudifornia
Just throwing this out there:
Looking for a MINT or better (~ 90% of the Yellow Chromate is still there) stock 81-87 USA Carburetor with the Cap for the Mix Screw intact, meaning the carb has not been disassembled or adjusted - see pic below for location of cap if you don't know. If you can see the slot for the mix screw, cap has been removed.
Will consider units with cap removed but Carb is MINT and has not been disassembled.
Will consider units with Fuel/Air Adjustment screw cap still intact but condition is not so minty fresh.
With all these bloody Sniper installs, somebody's got to have a good original carb they don't need :D
The closer to the pix below the better.
Thanks very much!
Mix Screw Plug location, hole has been drilled, just before removal.
What it should look like with CAP intact:
Just an FYI, the mixture screw is 2-3/4 out from seated from factory. I counted one with a cap (assuming it was not a replacement cap after manufacturing).
Still looking?
No, bought the one above.
Why, you wanna sell that NOS one in your display?
:D
I’m actually looking for a couple of cores. But I noticed that your thread wasn’t closed, and I got one recently that was still capped.
